06-03-2015 08:38 AM - edited 03-08-2019 12:23 AM
Hello everyone,
i have this problem on 2 switch 4503E
CORE01
%SFF8472-5-THRESHOLD_VIOLATION: Te1/1: Rx power low warning; Operating value: -13.8 dBm, Threshold value: -9.9 dBm.
%SFF8472-5-THRESHOLD_VIOLATION: Te1/1: Rx power low alarm; Operating value: -13.9 dBm, Threshold value: -13.9 d dBm.
4503E_CORE01#sh interfaces transceiver
Optical Optical
Temperature Voltage Tx Power Rx Power
Port (Celsius) (Volts) (dBm) (dBm)
Te1/1 23.9 3.26 -2.2 -14.0
4503E_CORE01#show inte te1/1 trans det
High Alarm High Warn Low Warn Low Alarm
Temperature Threshold Threshold Threshold Threshold
Port (Celsius) (Celsius) (Celsius) (Celsius) (Celsius)
Te1/1 24.1 75.0 70.0 0.0 -5.0
Voltage Threshold Threshold Threshold Threshold
Port (Volts) (Volts) (Volts) (Volts) (Volts)
Te1/1 3.26 3.60 3.50 3.10 3.00
Optical High Alarm High Warn Low Warn Low Alarm
Transmit Power Threshold Threshold Threshold Threshold
Port (dBm) (dBm) (dBm) (dBm) (dBm)
Te1/1 -2.2 1.6 -1.3 -7.3 -11.3
Receive Power Threshold Threshold Threshold Threshold
Te1/1 -13.9 1.9 -1.0 -9.9 -13.9
CORE02
%SFF8472-5-THRESHOLD_VIOLATION: Te1/1: Rx power low warning; Operating value: -13.5 dBm, Threshold value: -9.9 dBm.
4503E_CORE02#sh interfaces transceiver
Optical Optical
Te1/1 27.5 3.24 -2.3 -13.5
4503E_CORE02#show inte te1/1 trans det
Te1/1 27.4 75.0 70.0 0.0 -5.0
Te1/1 3.24 3.60 3.50 3.10 3.00
Te1/1 -2.1 1.6 -1.3 -7.3 -11.3
Te1/1 -13.5 1.9 -1.0 -9.9 -13.9
i only have 1 transceiver on both switch,i changed the fiber cord also the same issue.
Solved! Go to Solution.
06-03-2015 09:00 AM
Yes, for posts that are up and running, there is no workaround that I know and have not been able to get any good answer from Cisco, but they insist that this is a cosmetic error message.
sometimes replacing the SFP helps, but the error comes back again.
You may want to open a ticket with TAC. They may have a workaround in the newer versions.
09-29-2015 01:46 AM
I had this problem too
%SFF8472-5-THRESHOLD_VIOLATION: Gi1/0/50: Rx power low warning; Operating value: -17.7 dBm, Threshold value: -17.0 dBm.
We tried everything on this forum and then last night, a field engineer noticed that we were using single mode fibre cable and a multimode sfps. we chnaged the cable to multimode and (touch wood) since then the error has not occured since. It is also worth noticing we never saw any interface errors on the interface and that other forums suggest you can run sm fibre on mm sfp. This fibre had been in place for over a year and only recently started playing up. So in first instance I would recommend you have the correct fibre for the sfp and correct sm./mm patch panel.
06-03-2015 08:47 AM
This is usually not a transceiver or cable issue. This is a cosmetic bug that produces this message in the logs in most 4500 and 2960x series switches. If you have any unused SFP ports shutting them admin down sometimes help and for the fiber ports that are already connected, there isn't much of workaround, but the message does not cause any issue.
06-03-2015 08:50 AM
thanks Reza,
All port are shutdown
4503E_CORE01#sh int des
Interface Status Protocol Description
Te1/1 up up !!! Hacia 4503 Core02 !!!
Te1/2 admin down down
Te1/3 admin down down
Te1/4 admin down down
Te1/5 admin down down
Te1/6 admin down down
Te1/7 admin down down
Te1/8 admin down down
CORE02
4503E_CORE02#sh int des
Te1/1 up up !!! Hacia 4503 Core01 !!!
06-03-2015 09:00 AM
06-03-2015 09:04 AM
Thanks so much Reza, i will to update the both switches after i comment
09-29-2015 01:46 AM
10-04-2015 06:48 PM
The problem was solved with the correct cable.
03-17-2020 08:16 PM
Hi!
May I ask for the BugID of the error, since it was a cosmetic issue?
Thank you!
03-17-2020 11:51 PM
Few cosmetic bugs are actually filled as bugs, as these are considered low priority and rarely singled to TAC actually. There are way more important bugs to take care of, than cosmetic bugs.
Cristian Matei.
