CUCM with Fortigate
opnineopnine
I have a cluster 1 (publisher) 3 (sucribers) the last sucriber is on a remote site, but I can't make the DB sync, I can reach the Publisher.
The thing is I have firewall on both sides and they are Fortigate, my question is, is there any special configuration I have to do on the Fortigate
to fix the DB issue?
Thanks.
7 Replies 7
Jaime Valencia
Did you review the TCP and UDP port usage guide for CUCM and made sure nothing is getting blocked???
java
if this helps, please rate
yes sir,, all ports are open.
Hi.
Did configure a site to site vpn between those two firewalls?
Please refer to the following doc for tcp/udp communications on a CUCM cluster
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hello Carlo,
What doc?
Thanksl
Sorry
As usual I've forgotten the link:)
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/port/9_1_1/CUCM_BK_T2CA6EDE_00_tcp-port-usage-guide-91/CUCM_BK_T2CA6EDE_00_tcp-port-usage-guide-91_chapter_01.html
Sorry
Carlo
Hello Carlo,
I  already checked the ports and they are open as the document is requested.
Thanks.
Hi.
Have you checked the delay between Main and remote site ?
I remember you that it should be 40 ms one way.
Which is the output of a show network cluster
If possible post the result here
Let us know
Carlo
