Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1928846members
1242703discussions
Community Activity
Configure Port-channel and vPC in advance in Nexus 9K
hi,i'll be configuring a new N9K switch to replace a C9300.my question is, can i configure in advance the port-channel and vPC in the N9K even without the SFP inserted and fiber cables patched?just want to prepare the config so it will be a faster to...
UCSMにおけるPassword Encryption Keyについて
はじめにPassword Encryption Keyについて発生するエラーと解消法バックアップのタイミングの調整Password Encryption Keyの設定と文字制限参考情報 はじめに 本ドキュメントでは、Cisco UCS Manager release 4.2(3d)から導入された「Password Encryption Key」の概要と「Password Encryption Key」を設定しない場合に生じるエラーの解消法、設定の方法について説明します。 Password E...
daiogawa by Cisco Employee
  • 17 Views
  • 0 replies
Extended ACL inbound and outbound
Good morning friends,I have created two extended ACLs for in and out of my int vlan and applied it under int vlan for both directions inbound and outbound. I have created ACLs entries like this.For int vlan no. Out1 permit ip 10.1.0.0 0.0.255.255 hos...
IOS XE on Cat8kv AlwaysOn
I'm not able to ssh to devnetsandboxiosxe.cisco.com. I'm using the following command in Linux ssh admin@devnetsandboxiosxe.cisco.com. The response is...kex_exchange_identification: Connection closed by the remote hostConnection closed by 131.226.217....
Extremely slow and poor overall WiFi quality with C9130AXI
Recently swapped our 3802i APs for all C9130AXI to get the WiFi 6 capability. Have noticed very poor performance overall. Only change has been with the APs, nothing else. The controller remained to be an AIR 3504 and the switch is a Catalyst 3850 UPo...
NexCyb by Level 1
  • 46 Views
  • 1 replies
Intermittent Static noise on phones
We are a healthcare facility.  For past several months we have had several complaints from users that calls are often full of static.   We are running CUCM 12.5(1)SU8 and the phones are primarily 8811 running current firmware.   We have replaced phon...
Meraki Duo SSO through SAML
I'm tryign to set up Duo SSO for Meraki Client VPN, the knowledgebase seems out of date as it refers to choosing the Applciation Protect page when currently it's meant to use SAML. I have a few items I am not 100% sure where to get1) I think the enti...
CDragna by Level 1
  • 66 Views
  • 2 replies
DUO offline keeps looping
Hi. Our end-users suddenly has issue with DUO offline, it keeps on looping on the offline page. This only occurs on end-users who are on overseas or outside Singapore. Initially, they can log-in to their DUO, however after few days, they're already p...
PaulWP by Level 1
  • 87 Views
  • 1 replies
Duo Desktop not recognized
Hello, I am using Cisco Anyconnect to connect to VPN. The system is using Duo Desktop for device health. It is already installed, running and all the checks are ok. However, I am getting this error message and not able to proceed: Install Duo Desktop...
Sh2024 by Level 1
  • 76 Views
  • 1 replies
Allow ISE captive portal DNS entry on outside DNS.
Hello,We are having ISE for EAP/TACACS authentication and, hosted internally in our datacenter.Now we have configured BYOD captive portal that tied to AZURE SAML authentication, the current captive portal redirect URL from ISE has prepended the node ...
kshah2589 by Level 1
  • 1543 Views
  • 26 replies
AP9115axi
Hi ,I am facing one issue. AP9115AXI (access point) acquired IP address from DHCP. Confirmed with ARP table on switch.But  the command sh cdp nei detail - doesn't show IP address of AP. AP not yet associated to WLC.Any suggestion?With Regards,Ravindr...
