Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1927052members
1239467discussions
Community Activity
ISE DNS health check showing warning
Hi all,I have a four new standalone nodes which will be going into a cluster, I am seeing two nodes have a DNS warning. All nodes are located in the same caI can ping both DNS servers .21 and .22 and nslookup up works to resolve its own IPWhy are two...
Seeking Alternative Network Switch Recommendation for SG110D-08
Subject: Seeking Alternative Network Switch RecommendationHi,I hope you're doing well. We've discovered that the SG110D-08 network switch is no longer available. Could you please recommend an alternative that offers similar features and performance? ...
rmanuel by Level 1
  • 2 Views
  • 0 replies
Resolved! Outbound API Campaign Update Error
Greetings, Can you provide the URL and Body example to update a campaign via the Outbound API.  I am able to Create Campaign, Get Campaign Definition, Get Campaign Records, Import Campaign Records, Delete Campaign Records, and Delete Campaign, but th...
galguire by Level 4
  • 984 Views
  • 5 replies
connetion events in FMC
Hi Dears,in our company we have FMC\FTD but the logs (connection event) were saved for almost 1 week back only.i have been checked the limitation as the below tableConnection eventsSecurity Intelligence events50 million (FMC Virtual, FMC750) 100 mill...
khaled-jd by Level 1
  • 60 Views
  • 2 replies
9800 Guest Anchor Design
I am trying to understand Guest Anchoring with the 9800 Controllers. In the 5500 series WLCs you had to access the WMI from the inside network through the firewall to the Anchor Controller Mgmt Vlan on a DMZ.  Then create another sub-interface on the...
Redundancy Over VSAT Link
Hi, we have a WAN and VSAT connection to one of the site. WAN is primary and VSAT is secondary link.We have dedicated router for WAN and VSAT. VSAT link is connected to one of the LAN access switch.Could you please help me, what kind of configuration...
inhamit by Level 1
  • 136 Views
  • 5 replies
FTD 3100 AAA in Chassis mode
HiHow do we configure AAA for the FTD in chassis mode managed via FMC?I can't seem to find any information on this? The FXOS cli doesn't appear to permit you to make any changes.But i don't see anywhere to create a Chassis AAA policy. AAA for the Ins...
glsparks by Level 1
  • 78 Views
  • 2 replies
Cisco Research Opportunity: $20 gift card for your feedback
Cisco's Customer Experience (CX) Research is looking for customers and partners who have experience viewing an inventory of licenses or managing license renewals. If you qualify to participate in our 15 minute research activity, you will be rewarded ...
alnovoa by Cisco Employee
  • 102 Views
  • 1 replies
  • 1 Helpful votes
RF Heat Maps not shoiwng in Prime 3.10
Hi, We have recently deployed Prime 3.10.2 and added a 9800-L (SW 17.6.4) along with 10 X 9130 APs.. On adding the APs to the site maps within Prime, there is no RF heat maps being emitted from them. Just wondering if any has come across this issue a...
mac flapping
Apr 16 04:14:35.390: %SW_MATM-4-MACFLAP_NOTIF: Host 001b.0907.fe0e in vlan 11 is flapping between port Gi1/1/1 and port Gi1/1/2Apr 16 04:14:35.390: %SW_MATM-4-MACFLAP_NOTIF: Host 001b.0907.fe0e in vlan 11 is flapping between port Gi1/1/1 and port Gi1...
[Intersight] デバイスコネクタでの接続チェック
  はじめにデバイスコネクタの接続チェックの実行方法接続チェックの詳細内容とコピー方法エラー発生時の対処方法参考情報   はじめに Intersight とデバイスコネクタ間の通信に問題がある際はデバイスコネクタにて接続チェックを実施することで接続不良の原因の切り分けすることが可能です。本記事ではデバイスコネクタでの接続テストについて記載します。   デバイスコネクタの接続チェックの実行方法 1. デバイスコネクタの画面で [設定] をクリックし、進みます。   2. 左のタブで ...
Screenshot 041003.png Screenshot 041006.png Screenshot 041002.png Screenshot 041004.png
yusnakan by Cisco Employee
  • 16 Views
  • 0 replies
