06-18-2015 10:04 AM - edited 03-01-2019 09:15 AM
Hey all, new to this forum. I did a search but couldn't find anything. Excuse me if this has already been covered.
Currently I have a set of Jobgroups, each with multiple jobs in them, that need to run sequentially (with a dependency on the previous job) that kicks off at 9pm, and is expected to run until 4am the next day (roughly 100 jobs total). The jobrun duration of each job is not static -- it may be 1 min one day, or 1 hour. These jobs are all scheduled Daily (with some scheduled weekly).
Due to the midnight compilation of the schedule, I am uncertain of how job carryover will work, due to the dependencies.
Layout:
JobGroupRoot
.JobGroup1
..Job1
..Job2
.JobGroup2
..Job3
..Job4
..etc
If Job2 doesn't complete until Midnight, how can I make it so that Job3 runs? How does this affect the next days schedule. From my understanding, since all of the jobs will be compiled at midnight, the instance will run, but then the next run will be messed up due to job3 ->onwards have already been run for the day?
To make my question simpler: I have 100 jobs that need to run daily between 9pm and 4am the next day. Can this be done without changing the entire production or compilation offset?
Thanks in advance!
--Christian
06-18-2015 01:26 PM
Hi Christian,
The answer is YES. A few things to check, at system level and job/group-level.
System Level
Click on Activities from the top menu, and select configure scheduler. Select the appropriate option for your unfinished schedule (All Unfinished Jobs, unless disabled for job), and specify the number of days to carryover (ie, 1-3).
Job/group Level
Job Group Level Options, if job is currently running set this to Run Anyway
Job Level Options, if job is currently running, then set this to Defer Until Normal/Complete. Note the difference between defer until normal and complete. Complete here refers to any status regardless whether a job succeeds or fails. Also, if the disable carryover checkbox has a check mark, then this needs to be cleared in order for job to carryover.
Derrick Au
06-19-2015 08:36 AM
Thanks for the quick response! I've tried these options now, however it didn't work.
At Job Level Options, I've set all of them to defer until Normal.
An example of what happened was:
.JobGroup1
..Job1 11:30p completed normal at 11:54p
..Job2 11:55p completed normal at 12:01a
.JobGroup2
..Job3 12:00a SKIPPED
..Job4 12:00a SKIPPED
And then I looked at the current day, and job2 was carried over, however nothing after that was.
(btw i'm running 6.1.505)
06-19-2015 09:41 AM
Hi Christian,
Please confirm the following:
Derrick Au
06-19-2015 09:52 AM
Confirmed System Configuration, radio box set to All Unfinished Jobs. Days to Carryover set to 999
Confirmed each JobGroup is set to Run Anyway, and Disable carryover is unchecked
Confirmed each Job is set to Defer until normal, and Disable carryover is unchecked
Extra notes:
I have a time window set only on JobGroupRoot -- start time is set. No other jobs or jobgroups have a time window. There are job dependencies on each jobgroup that the previous completes normally.
06-19-2015 10:55 AM
Hi Christian,
JobGroupRoot means .JobGroup1?
Before the start of your jobs at 9:00pm, do ALL jobs appear on the schedule for current day? Or are there some jobs missing?
Do they all the run the same schedule (calendars)?
Derrick Au
06-19-2015 12:50 PM
JobGroupRoot means 1 context level higher
ie:
\jobgrouproot\jobgroup1\
\jobgrouproot\jobgroup1\job1
\jobgrouproot\jobgroup2\
All jobs are shown in the schedule, waiting on dependency status
All have the same job schedule calendar -- all are inherited.
To me, this would seem like it's a standard job pattern used by multiple companies, and I must be missing something really simple!
06-19-2015 01:01 PM
Hi Christian,
Lastly, please confirm the options on JobGroupRoot -- disable carryover option should not be checked.
Derrick Au
06-19-2015 01:04 PM
Confirmed. disable carryover option is unchecked (for this, and all jobgroups, and jobs)
09-19-2016 09:31 AM
chlouiying,
Did you find a resolution to this issue? If so, would you mind letting me know what it was?
Thanks.
TK
06-19-2015 01:13 PM
That was all I could think of at the moment, I am not sure why your jobs/groups/and root group does not get carried over past midnight. If all jobs/groups/root group are properly configured then it should behave as expected, but I must be missing something here as well...
