The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally. New Here? Click here to learn more and get started.
Cisco Community is an active and collaborative place to learn more about our products and ask questions of peers and Cisco experts! Check out some of the most popular conversations happening right now!
Hi We have requirements to configure three VLANs for single SSID on C9120 EWC. When we try to configure, we couldn't options for vlan groups anything like that.
Hello, i need some assistance. For the past 2 days i have been unable to login to skillsforall.com with my laptop, it just keep loading the rotating circle endlessly. Now https://skillsforall.com/ doesn't even load anymore, weird thing is it opens ju...
Hello Folks,Hope you are doing well.I am new to to the security and tring to setup a LAB with FTD and FMC.I just configured an interface of FTD from FMC but while deploying that getting error related to CPU and now trying to do it from CLI using API....
Is there a way to search or filter an ACP on the FMC for rules that has the default "Any" value parameter?The search rules option is the closest but what search parameter to put (ie. on source or destination networks) if I want see the policies that ...
The acquired building consists of a reception department and an administration + management department. After consulting with the team, designed the following layout. After some minor adjustments, our our technical department to install the hardware ...
Hello,I am trying to implement control plane policies on my test equipment, my cto is asking me to limit the ICMP max rate for all untrusted addresses. (I have to create an exception for knows hosts)Having very little experience in CoPP, I believed t...
Hello guys, below is my topology,I have added internet fw and introduced ISP on site B.Before site B resources/ servers would go via mpls to site a to access internet.I introduced the above to make each site use its own isp respectively.I ran to cha...
I have identified at least 2 quiz questions that identify correct answer as incorrect:12.3.3 Gateways to Other Networks QuizQuestion 5If the default gateway is configured incorrectly on a host, what is the impact on communications? 1. The host is una...
Hello,I need some help with the following BGP configuration router bgp 300neighbor 192.169.10.1 remote-as 200neighbor 192.169.10.1 description ISP-Aneighbor 192.169.20.1 remote-as 400neighbor 192.169.20.1 description ISP-B!address-family ipv4network ...
Hello, A customer are having some issues with performances when the CPU of there FTD 2130 sometimes reach 90% and start dropping traffic due to occasionally high amount of traffic. This is mostly internal traffic within a Kubernetes cluster. If we w...
Good night for all.I'm trying to import a translation pattern csv file (previously exported) and it doesn't work.When I verify the file, I seems to be ok but when I try to import it, appears a message in the log file that indicates "translation patte...
Hi everyone! My team has decided to create a Docker container with NSO 6.1.7. The image contains a NSO System Install and a few NEDs and packages built with Python. NSO 6.1 seems to perfectly work with M2 outside of the container. So we are sure thi...
On APIC-M2 where I have 2 phy fabric connections but at the GUI I have seen 4 phy interfaces, can someone help to explain the relationship or mapping between them. I am going to replace the APIC-M2 with APIC-M4 soon and need to move all the phy conne...
Hi,A user raised an issue to the IT department, he was trying to join a internal MS teams call that is SIP enabled on a cisco webex room kit.Normally there are no issues joining but when he tried he got "Invalid VTC", I tried in another room and same...
