06-22-2015 09:43 PM - edited 07-05-2021 03:26 AM
Can anyone tell me steps for converting Cisco AIR-CAP1602I-N-K9 to Air-SAP1602I-N-K9 and vice versa. Also, advise while converting if any feature will not be available after converting from Cisco AIR-CAP1602I-N-K9 to Air-SAP1602I-N-K9 and vice versa.
Solved! Go to Solution.
06-22-2015 09:56 PM
Here are example for these conversion
http://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
http://mrncciew.com/2013/12/13/ap-conversion-using-mode-button/
Featurewise controller based solution have more advanced features where as standalone lack of. In standalone mode, you have to manage them individually where as in controller based solution, you only need to manage config in WLC, it will automatically push config to AP.
Rasika
*** Pls rate all useful responses ***
06-22-2015 09:56 PM
Rasika
07-01-2015 05:21 AM
Thanks.
Please suggest how to download autonomous IOS and lightweight recovery image of Cisco AP1600 and it's URL.
If you can share some more features lacking between each other apart from one push centralized management through WLC. It will be great help for me.
07-13-2015 05:31 AM
Hi Rasika,
I am not able to convert LWAP to Autonomous. As,AP's default IP address 10.0.0.1/24 is not reachable from my laptop. All physical media(straight cable) is cross checked by me. Some of outputs and details are under mentioned. It might help to trace the root cause. Thanks in advance.
1: My Lappy ipconfig detail.
2: Show running-config
3: Show version
4 : Move in global configuration mode to provide static IP address to Ethernet interface.
5: Ping from AP console to my Lappy(TFTP Server).
1: My Lappy ipconfig detail :
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\amar>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : amar-PC
Primary Dns Suffix . . . . . . . : dartsit.co.in
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : dartsit.co.in
Ethernet adapter TGB No Tunnel:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : TheGreenBow Virtual Miniport Adapter
Physical Address. . . . . . . . . : 02-50-F2-7C-A7-04
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : Atheros AR9285 802.11b/g WiFi Adapter
Physical Address. . . . . . . . . : F0-7B-CB-3D-49-4A
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Realtek RTL8102E/RTL8103E Family PCI-E Fa
st Ethernet NIC (NDIS 6.20)
Physical Address. . . . . . . . . : C8-0A-A9-2D-6B-9E
Link-local IPv6 Address . . . . . : fe80::959d:f3e8:8765:5c0a%11(Preferred)
IPv4 Address. . . . . . . . . . . : 10.0.0.5(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 10.0.0.1
DHCPv6 IAID . . . . . . . . . . . : 247990953
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1C-83-DD-59-C8-0A-A9-2D-6B-9E
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
NetBIOS over Tcpip. . . . . . . . : Enabled
User Access Verification
Username: Cisco
Password:
AP881d.fc10.dcb1>ena
AP881d.fc10.dcb1>enable
Password:
AP881d.fc10.dcb1#
AP881d.fc10.dcb1#show runn
AP881d.fc10.dcb1#show running-config
Building configuration...
Current configuration : 12258 bytes
! Last configuration change at 00:00:33 UTC Mon Mar 1 1993
version 15.2
no service pad
hostname AP881d.fc10.dcb1
logging rate-limit console 9
enable secret 5 $1$RZGw$RuleMM5wMbeNiq9pzqo8a/
aaa new-model
aaa authentication login default local
aaa session-id common
ip cef
power inline negotiation prestandard source
crypto pki trustpoint airespace-old-root-cert
revocation-check none
rsakeypair Cisco_IOS_MIC_Keys
crypto pki trustpoint airespace-device-root-cert
crypto pki trustpoint Cisco_IOS_MIC_cert
crypto pki certificate chain airespace-old-root-cert
certificate ca 00
30820406 3082032F A0030201 02020100 300D0609 2A864886 F70D0101 04050030
818F310B 30090603 55040613 02555331 13301106 03550408 130A4361 6C69666F
726E6961 3111300F 06035504 07130853 616E204A 6F736531 16301406 0355040A
130D6169 72657370 61636520 496E6331 0D300B06 0355040B 13046E6F 6E65310B
30090603 55040313 02636131 24302206 092A8648 86F70D01 09011615 73757070
6F727440 61697265 73706163 652E636F 6D301E17 0D303330 32313232 33333835
355A170D 31323131 31313233 33383535 5A30818F 310B3009 06035504 06130255
53311330 11060355 0408130A 43616C69 666F726E 69613111 300F0603 55040713
0853616E 204A6F73 65311630 14060355 040A130D 61697265 73706163 6520496E
63310D30 0B060355 040B1304 6E6F6E65 310B3009 06035504 03130263 61312430
2206092A 864886F7 0D010901 16157375 70706F72 74406169 72657370 6163652E
636F6D30 81DF300D 06092A86 4886F70D 01010105 000381CD 003081C9 0281C100
DB9D3901 30059DD1 05CB2793 9B9907F8 1FF57FA9 24065BF7 1A5865F8 B9CFCCB3
679354D4 69BAB847 1CA327AE EA006AAC 90479C9D C23B67DE FACC0D28 32C6103F
A59C41E2 E8B4250B 4D2903EB 52629A99 D618B747 C4A94151 1AB995BB 14905404
5F4A0B9F F387F346 D5F3A249 2AED1B6A 3DD639D8 4924366A 1234DD2D B13CD489
7E2EA101 63BCCC82 2F7A6D0B 33AB5705 3C784A6D A3DD1E5B 96CF54C6 CF4D59BC
1BFD6CB6 E72FCB29 88DCBE6D 4D76FB83 1FAF5683 E4E20822 00A9EB2E 3BEF0DF9
02030100 01A381EF 3081EC30 1D060355 1D0E0416 04149457 DF7D1482 2D31BB28
772E8996 1886DA46 84BA3081 BC060355 1D230481 B43081B1 80149457 DF7D1482
2D31BB28 772E8996 1886DA46 84BAA181 95A48192 30818F31 0B300906 03550406
13025553 31133011 06035504 08130A43 616C6966 6F726E69 61311130 0F060355
04071308 53616E20 4A6F7365 31163014 06035504 0A130D61 69726573 70616365
20496E63 310D300B 06035504 0B13046E 6F6E6531 0B300906 03550403 13026361
31243022 06092A86 4886F70D 01090116 15737570 706F7274 40616972 65737061
63652E63 6F6D8201 00300C06 03551D13 04053003 0101FF30 0D06092A 864886F7
0D010104 05000381 C100AEB0 349DC0F9 2AAA3A57 75B3A79C 5421A9D0 15389261
95C03479 04DA81D4 120F58FA E2299223 BEB54A90 6D70F7F7 2192EFAF A4B0F488
604E3094 BBCC77A3 60A88129 0849B87B 5CA1AA17 21922A55 6B68E0D3 1ADC7264
C4C4D6B2 33345C86 254E4988 096645CD 40F12761 8BC37E71 DAD91677 25322361
71D87A16 F92AF7C1 51CB8892 443BC666 59BEA47B 985E8866 68A1EBD4 88BBF6E7
A949FDF8 7711D518 A80E203D A12BEBDC 6963EDA7 B76079A3 22380C96 0CB8D324
CADD949D EA39E0EF 033D
quit
crypto pki certificate chain airespace-device-root-cert
certificate ca 03
3082047F 308203A8 A0030201 02020103 300D0609 2A864886 F70D0101 04050030
81A6310B 30090603 55040613 02555331 13301106 03550408 130A4361 6C69666F
726E6961 3111300F 06035504 07130853 616E204A 6F736531 17301506 0355040A
130E4169 72657370 61636520 496E632E 31143012 06035504 0B130B45 6E67696E
65657269 6E67311A 30180603 55040313 11416972 65737061 63652052 6F6F7420
43413124 30220609 2A864886 F70D0109 01161573 7570706F 72744061 69726573
70616365 2E636F6D 301E170D 30353034 32383232 33373133 5A170D31 35303132
36323233 3731335A 3081A831 0B300906 03550406 13025553 31133011 06035504
08130A43 616C6966 6F726E69 61311130 0F060355 04071308 53616E20 4A6F7365
31173015 06035504 0A130E41 69726573 70616365 20496E63 2E311430 12060355
040B130B 456E6769 6E656572 696E6731 1C301A06 03550403 13134169 72657370
61636520 44657669 63652043 41312430 2206092A 864886F7 0D010901 16157375
70706F72 74406169 72657370 6163652E 636F6D30 81DF300D 06092A86 4886F70D
01010105 000381CD 003081C9 0281C100 A93C0158 E7284E75 FF86A57A 886ACA37
430BECF0 7582F56B DB6AC514 554FB06E AA327B3E CE3C9391 03C93BA4 0C0AF932
A6CB5DA3 F1C3C528 53BF4E19 2C1BFC48 467EBD93 06B4974A 1273BF35 8AD8540F
261E612B A2673B68 D239C87E 1E9E967B 2654D285 45BB7F78 5F4E9D4B 7B8001AA
2F455CFF 4552ECDB 5667E3FC E7093E06 8FAE353D 4228B48D 8B415D9B F496342D
C1459987 B69BFA4B 51FB67B4 A0C21E7F C6269A39 47EB1D48 5E83B129 8B079E5E
1EDAB5A0 BE5E1DE0 109FF0BD 4750E32B 02030100 01A38201 37308201 33300C06
03551D13 04053003 0101FF30 2E060960 86480186 F842010D 0421161F 41697265
73706163 65204465 76696365 20434120 43657274 69666963 61746530 1D060355
1D0E0416 04140A52 3BB12570 523B9CEA 747FB2AD 3D8F95EA 3FCC3081 D3060355
1D230481 CB3081C8 8014538D 8360478D C20F8066 3232E9E1 7070552B 17EAA181
ACA481A9 3081A631 0B300906 03550406 13025553 31133011 06035504 08130A43
616C6966 6F726E69 61311130 0F060355 04071308 53616E20 4A6F7365 31173015
06035504 0A130E41 69726573 70616365 20496E63 2E311430 12060355 040B130B
456E6769 6E656572 696E6731 1A301806 03550403 13114169 72657370 61636520
526F6F74 20434131 24302206 092A8648 86F70D01 09011615 73757070 6F727440
61697265 73706163 652E636F 6D820100 300D0609 2A864886 F70D0101 04050003
81C100A0 E8D59D9B DA9EED0C 96045DFE A37084EC 59B5C3D3 71694DB0 70664E0C
8060D69E E366E81F 9F3CCF68 8AB0498E CCFA6CA7 2854F2D8 046690C9 8FEC84EF
2F7F0F08 C90F719D C0F4C125 CED1B525 6DD93E51 777BD5E8 7F1DC79F CC502DC2
0242C05D 1682DEE3 DF7541B8 C55B433C 10DFE2BF D2E802E7 D923329A 23A2076F
86BCC048 D569B383 59AC8979 97F02C55 6F8FE318 754F605C 43CDA7C8 1847B085
1DADF0D6 CD62C8DE A86E6E12 4A7CDCBF A6FCC7E1 852A1DB1 529D63B3 688305F6 7BD25F
quit
crypto pki certificate chain Cisco_IOS_MIC_cert
certificate 46BA6B340000001ED9CB
30820470 30820358 A0030201 02020A46 BA6B3400 00001ED9 CB300D06 092A8648
86F70D01 01050500 30393116 30140603 55040A13 0D436973 636F2053 79737465
6D73311F 301D0603 55040313 16436973 636F204D 616E7566 61637475 72696E67
20434130 1E170D31 34313032 33323132 3333385A 170D3234 31303233 32313333
33385A30 818C310B 30090603 55040613 02555331 13301106 03550408 130A4361
6C69666F 726E6961 3111300F 06035504 07130853 616E204A 6F736531 16301406
0355040A 130D4369 73636F20 53797374 656D7331 1B301906 03550403 13124150
3147322D 38383164 66633130 64636231 3120301E 06092A86 4886F70D 01090116
11737570 706F7274 40636973 636F2E63 6F6D3082 0122300D 06092A86 4886F70D
01010105 00038201 0F003082 010A0282 010100C1 C57FB999 260162BD A810E043
D4F1F086 860A7645 4E37A839 694192BF B6F2BD7C B4AD186D A45DC3B2 FB0E3AE3
07EEB5A2 A3FEDDC2 EB21665D 0FAD483E 584DB497 0051B79E 71D1376E D86ACB6F
F82048FF A59014DD 015CCB43 69F42185 0E2343CE 117270B5 0BA436AF 1B303CE0
997B036C F428607B 622EB86D F948BAD4 9DACEA8E 9197728F 3121DC63 59800FDB
06D576C0 22F211A0 298A58DD F3F00316 AFD17063 CFFA70CB 80AB1482 40A7EB27
52630246 3C416FCA 8AEFDC63 04CF3304 3E9473F6 55E2D017 941632FB DF796953
F50286FB 8A3682AB C879266F E60D28C5 B5B84987 4766DC1C F63DCB8F FDAC0D53
C71C87C7 5D76ABC3 80210BC5 65CADF9C 36740902 03010001 A3820124 30820120
300E0603 551D0F01 01FF0404 030205A0 301D0603 551D0E04 160414FA 4E5BA2FD
F2B5E7B5 03C7C964 E96D56D9 9A4B3830 1F060355 1D230418 30168014 D0C52226
AB4F4660 ECAE0591 C7DC5AD1 B047F76C 303F0603 551D1F04 38303630 34A032A0
30862E68 7474703A 2F2F7777 772E6369 73636F2E 636F6D2F 73656375 72697479
2F706B69 2F63726C 2F636D63 612E6372 6C304C06 082B0601 05050701 01044030
3E303C06 082B0601 05050730 02863068 7474703A 2F2F7777 772E6369 73636F2E
636F6D2F 73656375 72697479 2F706B69 2F636572 74732F63 6D63612E 63657230
3F06092B 06010401 82371402 04321E30 00490050 00530045 00430049 006E0074
00650072 006D0065 00640069 00610074 0065004F 00660066 006C0069 006E0065
300D0609 2A864886 F70D0101 05050003 82010100 599C7311 6902110A EB9CEB12
88633B7E C076A10F B9501C0B 5FA0479A 886A69B4 1819A10A 90095684 12F06888
EC0B16A2 ACAC46ED 1EE316B1 7F77E61E 8C57FE66 AD6482C0 DA715D2E 76E93E21
3DB63299 227DDA0A 68D3D4BB F2558FC6 7648FBD5 D27D3FD8 07114187 0F56ABBE
27D13E7C 5C2FB608 D2EA1049 C9E457CB 7315022F BCD822B2 BEFD5C04 ECE2E159
889A0DC9 C203703F 6C398FBE 0E75E9A5 652ADCDC 94AC55D4 8EBC3C34 1C7DF955
CF55B3D4 B31F0B89 30CEFFF6 CE13E6B7 9EB796CF 37D2D265 86D2829A AAC468C1
9E559A17 F4D88DE7 92DB4D21 51524835 32BAD6F2 ABFAA991 49746BBB C04ED784
50668855 85FB600D 33E7E8AC 11E3E142 9B60C3AE
quit
certificate ca 6A6967B3000000000003
308204D9 308203C1 A0030201 02020A6A 6967B300 00000000 03300D06 092A8648
86F70D01 01050500 30353116 30140603 55040A13 0D436973 636F2053 79737465
6D73311B 30190603 55040313 12436973 636F2052 6F6F7420 43412032 30343830
1E170D30 35303631 30323231 3630315A 170D3239 30353134 32303235 34325A30
--More--
*Mar 1 01:45:53.667: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewin 39311630 14060355 040A130D 43697363 6F205379 7374656D 73311F30 1D060355
04031316 43697363 6F204D61 6E756661 63747572 696E6720 43413082 0120300D
06092A86 4886F70D 01010105 00038201 0D003082 01080282 010100A0 C5F7DC96
943515F1 F4994EBB 9B41E17D DB791691 BBF354F2 414A9432 6262C923 F79AE7BB
9B79E807 294E30F5 AE1BC521 5646B0F8 F4E68E81 B816CCA8 9B85D242 81DB7CCB
94A91161 121C5CEA 33201C9A 16A77DDB 99066AE2 36AFECF8 0AFF9867 07F430EE
A5F8881A AAE8C73C 1CCEEE48 FDCD5C37 F186939E 3D71757D 34EE4B14 A9C0297B
0510EF87 9E693130 F548363F D8ABCE15 E2E8589F 3E627104 8726A415 620125AA
D5DFC9C9 5BB8C9A1 077BBE68 92939320 A86CBD15 75D3445D 454BECA8 DA60C7D8
C8D5C8ED 41E1F55F 578E5332 9349D5D9 0FF836AA 07C43241 C5A7AF1D 19FFF673
99395A73 67621334 0D1F5E95 70526417 06EC535C 5CDB6AEA 35004102 0103A382
01E73082 01E33012 0603551D 130101FF 04083006 0101FF02 0100301D 0603551D
0E041604 14D0C522 26AB4F46 60ECAE05 91C7DC5A D1B047F7 6C300B06 03551D0F
04040302 01863010 06092B06 01040182 37150104 03020100 30190609 2B060104
01823714 02040C1E 0A005300 75006200 43004130 1F060355 1D230418 30168014
27F3C815 1E6E9A02 0916AD2B A089605F DA7B2FAA 30430603 551D1F04 3C303A30
38A036A0 34863268 7474703A 2F2F7777 772E6369 73636F2E 636F6D2F 73656375
72697479 2F706B69 2F63726C 2F637263 61323034 382E6372 6C305006 082B0601
05050701 01044430 42304006 082B0601 05050730 02863468 7474703A 2F2F7777
772E6369 73636F2E 636F6D2F 73656375 72697479 2F706B69 2F636572 74732F63
72636132 3034382E 63657230 5C060355 1D200455 30533051 060A2B06 01040109
15010200 30433041 06082B06 01050507 02011635 68747470 3A2F2F77 77772E63
6973636F 2E636F6D 2F736563 75726974 792F706B 692F706F 6C696369 65732F69
6E646578 2E68746D 6C305E06 03551D25 04573055 06082B06 01050507 03010608
2B060105 05070302 06082B06 01050507 03050608 2B060105 05070306 06082B06
01050507 0307060A 2B060104 0182370A 0301060A 2B060104 01823714 02010609
2B060104 01823715 06300D06 092A8648 86F70D01 01050500 03820101 0030F330
2D8CF2CA 374A6499 24290AF2 86AA42D5 23E8A2EA 2B6F6923 7A828E1C 4C09CFA4
4FAB842F 37E96560 D19AC6D8 F30BF5DE D027005C 6F1D91BD D14E5851 1DC9E3F7
38E7D30B D168BE8E 22A54B06 E1E6A4AA 337D1A75 BA26F370 C66100A5 C379265B
A719D193 8DAB9B10 11291FA1 82FDFD3C 4B6E65DC 934505E9 AF336B67 23070686
22DAEBDC 87CF5921 421AE9CF 707588E0 243D5D7D 4E963880 97D56FF0 9B71D8BA
6019A5B0 6186ADDD 6566F6B9 27A2EE2F 619BBAA1 3061FDBE AC3514F9 B82D9706
AFC3EF6D CC3D3CEB 95E981D3 8A5EB6CE FA79A46B D7A25764 C43F4CC9 DBE882EC
0166D410 88A256E5 3C57EDE9 02A84891 6307AB61 264B1A13 9FE4DCDA 5F
quit
username Cisco secret 5 $1$ohww$7ZJZTT5I5C10UtBWksqOT/
bridge irb
interface GigabitEthernet0
duplex auto
speed auto
interface GigabitEthernet0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 spanning-disabled
interface BVI1
ip address dhcp client-id BVI1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 BVI1
bridge 1 protocol ieee
bridge 1 route ip
line con 0
line vty 0 4
transport input none
line vty 5 15
end
AP881d.fc10.dcb1#
AP881d.fc10.dcb1#
AP881d.fc10.dcb1#
3: Show version
AP881d.fc10.dcb1#show version
Cisco IOS Software, C1600 Software (AP1G2-RCVK9W8-M), Version 15.2(4)JA1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 30-Jul-13 23:41 by prod_rel_team
ROM: Bootstrap program is C1600 boot loader
BOOTLDR: C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFTWARE (fc1)
AP881d.fc10.dcb1 uptime is 1 hour, 47 minutes
System image file is "flash:/ap1g2-rcvk9w8-mx/ap1g2-rcvk9w8-mx"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1602I-A-K9 (PowerPC) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FCW1843JETG
PowerPC CPU at 533Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.5.1.73
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 88:1D:FC:10:DC:B1
Part Number : 73-14671-04
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : FOC18426HPX
Top Assembly Part Number : 800-102028-02
--More--
*Mar 1 01:47:33.666: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. RenewinTop Assembly Serial Number : FCW1843JETG
Top Revision Number : A0
Product/Model Number : AIR-CAP1602I-A-K9
Configuration register is 0xF
AP881d.fc10.dcb1#
AP881d.fc10.dcb1#configure terminal
% Invalid input detected at '^' marker.
AP881d.fc10.dcb1#
AP881d.fc10.dcb1#ping 10.0.0.5
% Unrecognized host or address, or protocol not running.
AP881d.fc10.dcb1#
Amar Shahi
