06-23-2015 04:38 PM - edited 03-19-2019 09:44 AM
Hello All,
Has anyone experienced an issue where ELM can sync to a CUCM publisher but it shows no license usage. This is on CUCM 10.5.2 after a PCD migration. I have restarted ELM services and licensing manager on the PUB with no success. I have a TAC case open. Thanks
Jason
Solved! Go to Solution.
06-23-2015 08:15 PM
Hi Jason,
Have you tried deleting and re-adding the product instance on ELM followed by a restart of License Manager service on cucm Pub.
Manish
07-01-2015 08:56 AM
thanks for update.
what exactly u mean by time was off between ELM GUI and pub ?can u please explain.
regds,
aman
06-23-2015 08:15 PM
Hi Jason,
Manish
06-24-2015 03:57 AM
Not cam e across this issue.
Have u tried changing the browser?
secondly, u can look into the bug which talks about similar issue
since u have TAC case already opened ,let us wait for the resolution.
regds,
aman
07-01-2015 07:33 AM
Hello All,
This has been fixed by TAC, the issue was the Time was off between the ELM gui and the Call Manager PUB gui. I had to do a set timezone command again from the CLI of the PUB and reboot. Once I did that I was able to synchronize in ELM and see my usage. Thanks
07-01-2015 08:56 AM
thanks for update.
regds,
aman
08-10-2015 09:59 AM
Well the Time Zone in the CLI of the PUB was incorrect, so I had to set it to EST, then restart the Publisher. I think the enterprise licensing manager has its own time and it was not the same as the Publishers time. So this is what fixed the issue.
08-11-2015 08:07 AM
thanks for update[+5]
Is this documented somewhere or you spoke to Cisco TAC?
regds,
aman
