06-24-2015 07:53 AM - edited 03-11-2019 11:10 PM
I have two ASA5505 with security plus license.
The two ASAs are identical apart from ANYCONNECT ESSENTIAL license which is enabled only in one of the firewall.
When I try to configure failover i get the following message:
" Mate's license (AnyConnect Essentials Enabled) is not compatible with my license (AnyConnect Essentials Disabled). Failover will be disabled."
Is there a way to disable anyconnect essential in order to have the two unit working in a failover architecture?
Thank you all
Johnny
Solved! Go to Solution.
06-24-2015 08:16 PM
You can first upgrade to 8.3+ where licenses need not match to form an HA pair.
06-24-2015 08:16 PM
06-25-2015 01:26 AM
Thank you very much.
Unfortunately my costumer doesn't want to upgrade to 8.3+.
Isn't there another way to let them pair in 8.2.5 release?
Tks
06-25-2015 04:18 PM
You're welcome.
You can add AnyConnect Essentials to the unit that doesn't have it.
Part number L-ASA-AC-E-5505= list price US$100.
It's approaching end of sales and available only through 31 August 2015. The older AnyConnect Essentials package is being replaced with the new AnyConnect Plus product which also has mobile support built in.
