CSCul25263 - Seagate 146/300/500GB/1TB/2TB HDDs may stop responding
jeffnachatilo
How do we determine the existing hard drive firmware for this bug?
Bug ID CSCul25263 - Seagate 146/300/500GB/1TB/2TB HDDs may stop responding.
Jeff
scott.braun
From the CIMC web interface, go to Inventory, then the Storage tab, and then the Physical Drive Info tab beneath that. There should be a Drive Firmware column which lists the current version.
CIMC web interface works for point & click through GUI.
However, I have 170 servers to audit.
Is there a procedure to find this HD Firmware via CLI?
ucs-c2xx-m2# show
  bios           System BIOS: Basic Input/Output System
  certificate    Security Certificates for SSH & SSL
  chassis        Server Inventory Items
  cimc           Cisco Integrated Management Controller
  configuration  Configuration
  fault          Configure alerts on platform events/fault
  http           Hyper Text Transfer Protocol
  ipmi           Intelligent Platform Management Interface
  kvm            Keyboard Video Mouse console to host
  ldap           Lightweight Directory Access Protocol
  power-cap      Power monitoring and control
  snmp           Simple Network Management Protocol
  sol            Serial Over Lan (character mode console to Host)
  ssh            Secure Shell Configuration
  user           Local users of this CIMC
  user-session   Active user sessions on this CIMC
  version        Firmware version
  vmedia         Virtual Media (mount local media onto Host)
  xmlapi         XML API Configuration
Jeff
I figured it out, and sharing here (including status of RAID controller Battery Backup):
ucs-c2xx-m2# scope chassis
ucs-c2xx-m2 /chassis # show storageadapter
PCI Slot Product Name                       Serial Number  Firmware Package Build             Product ID     Battery Status Cache Memory Size
SLOT-5   LSI MegaRAID SAS 9261-8i           SV15304376     12.12.0-0060                       LSI Logic      fully charged  394 MB
ucs-c2xx-m2 /chassis # scope storageadapter SLOT-5
ucs-c2xx-m2 /chassis/storageadapter # show physical-drive
Physical Drive Number Controller Status                 Manufacturer   Model          Predictive Failure Count Drive Firmware Coerced Size   Type
1                     SLOT-5     online                 FUJITSU        MBE2147RC      0                        5701           139236 MB      HDD
2                     SLOT-5     online                 FUJITSU        MBE2147RC      0                        5701           139236 MB      HDD
3                     SLOT-5     online                 FUJITSU        MBE2147RC      0                        5701           139236 MB      HDD
4                     SLOT-5     online                 FUJITSU        MBE2147RC      0                        5701           139236 MB      HDD
5                     SLOT-5     online                 FUJITSU        MBE2147RC      0                        5701           139236 MB      HDD
6                     SLOT-5     online                 FUJITSU        MBE2147RC      0                        5701           139236 MB      HDD
7                     SLOT-5     online                 FUJITSU        MBE2147RC      0                        5701           139236 MB      HDD
8                     SLOT-5     online                 FUJITSU        MBE2147RC      0                        5701           139236 MB      HDD
9                     SLOT-5     online                 FUJITSU        MBE2147RC      0                        5701           139236 MB      HDD
10                    SLOT-5     online                 FUJITSU        MBE2147RC      0                        5701           139236 MB      HDD
ucs-c2xx-m2 /chassis/storageadapter # show bbu detail
Controller SLOT-5:
    Battery Type: iBBU
    Battery Present: true
    Voltage: 3.947 V
    Current: 0.000 A
    Charge: 100%
    Charging State: fully charged
    Temperature: 27 degrees C
    Voltage Low: false
    Temperature High: false
    Learn Cycle Requested: false
    Learn Cycle Active: false
    Learn Cycle Failed: false
    Learn Cycle Timeout: false
    I2C Errors Detected: false
    Battery Replacement Required: true
    Remaining Capacity Low: true
