Extract config files from Cisco Prime Infrastructure
CB90021204
When devices are removed from Cisco Prime Infrastructure, all the configuration files are lost. I want to retain the configuration for reference on future network projects.
I was wondering if I can access the files and back them up if possible.  On CWLMS 3.2 I could access the files at the link below. Is there a similar location within Cisco Prime?
"\\server name\c$\Program Files (x86)\CSCOpx\files\rme\dcma\shadow"
AFROJ AHMAD
Hi ,
check these post for your answer
https://supportforums.cisco.com/discussion/12036841/prime-infrastructure-20-device-configurations
https://supportforums.cisco.com/discussion/11852236/pi-where-devices-archive-files-are-located#3975460
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi ,
Thanks-
Afroz
