06-26-2015 01:39 AM - edited 07-05-2021 03:28 AM
I try to connect AP 1552E to WLC 4400 with version 7.0.251.2.
i allready input the mac to the :
WLC GUI>>Secuirty>>AAA>AP policies>>Add
and
WLC GUI>> Security>>Mac Filtering
but the AP still not connected.
Here is the log from WLC.
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Jun 25 01:28:22.779: status of voice_diag_test from WLC is false
*Jun 25 01:28:35.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.29.77.252 peer_port: 5246
*Jun 25 01:28:35.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 25 01:28:35.647: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.29.77.252 peer_port: 5246
*Jun 25 01:28:35.647: %CAPWAP-5-SENDJOIN: sending Join Request to 172.29.77.252
*Jun 25 01:28:35.647: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 25 01:28:35.651: %DTLS-5-ALERT: Received WARNING : Close notify alert from 172.29.77.252
*Jun 25 01:28:35.651: %DTLS-5-PEER_DISCONNECT: Peer 172.29.77.252 has closed connection.
*Jun 25 01:28:35.651: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.29.77.252:5246
*Jun 25 01:28:35.651: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.29.77.252 peer_port: 5246
*Jun 25 01:28:35.651: %CAPWAP-5-SENDJOIN: sendin
% CDP is not supported on this interface, or for this encapsulation
Translating "CISCO-LWAPP-CONTROLLER"...domain server (255.255.255.255)g Join Request to 172.29.77.252
*Jun 25 01:28:35.651: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 25 01:28:35.655: %DTLS-5-PEER_DISCONNECT: Peer 172.29.77.252 has closed connection.
*Jun 25 01:28:35.655: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.29.77.252:5246
*Jun 25 01:28:35.651: %CAPWAP-5-SENDJOIN: sending Join Request to 172.29.77.252
Please help..
06-26-2015 08:36 PM
What is the AP iOS?
12.4(23c)JA9 |
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#12307
06-26-2015 08:56 PM
Hi Charles,
I allready use IOS version 12.4(23c)JA9
here's output of show version command
Cisco IOS Software, C1550 Software (C1520-K9W8-M), Version 12.4(23c)JA9, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 03-Dec-14 12:02 by prod_rel_team
ROM: Bootstrap program is C1550 boot loader
BOOTLDR: C1550 Boot Loader (C1520-BOOT-M) LoaderVersion 15.2(2a)JA, RELEASE SOFTWARE (fc1)
AP1cde.a7de.1fe0 uptime is 10 minutes
System returned to ROM by reload
System image file is "flash:/c1520-k9w8-mx.124-23c.JA9/c1520-k9w8-mx.124-23c.JA9"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1552E-C-K9 (PowerPC 8349) processor (revision A0) with 49142K/16384K bytes of memory.
Processor board ID FGL1839Y006
PowerPC 8349 CPU at 533Mhz, revision number 0x0031
Last reset from reload
LWAPP image version 7.0.251.2
AVR Microcontroller 1 - SW Version: 00.01.02
AVR Microcontroller 2 - SW Version: 00.01.09
AVR Microcontroller 6 - SW Version: 00.01.00
4 Gigabit Ethernet interfaces
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 1C:DE:A7:DE:1F:E0
Part Number : 73-13538-02
PCA Assembly Number : 800-31224-01
PCA Revision Number : 03
PCB Serial Number : FOC1831B2Y1
Top Assembly Part Number : 800-34853-05
Top Assembly Serial Number : FGL1839Y006
Top Revision Number : A0
Product/Model Number : AIR-CAP1552E-C-K9
Thank you very much.
