06-28-2015 08:12 AM - edited 03-11-2019 11:11 PM
Hi everyone,
I have below nat config on ASA
nat (outside,any) source static vpn_pool_ip vpn_pool_ip destination static inside inside description Allow Ping and SSH to 10.0.0.1 using Anyconnect with Full Tunnel
nat (inside,outside) source static inside inside destination static vpn_pool_ip vpn_pool_ip
nat (inside,outside) source static inside inside destination static inside inside
nat (outside,outside) source dynamic vpn_pool_ip interface description Allow Access to Internet using Anyconnect VPN
nat (sales,outside) source static Sales Sales destination static Sales Sales
nat (inside,outside) source dynamic inside interface description Allow R1 to ping to Internet Sites
nat (sales,outside) source dynamic Sales interface description Allow 2950 to Pint to Internet Sites
nat (sales,outside) source static Sales Sales destination static vpn_pool_ip vpn_pool_ip description Allow Ping to 2950 Switch while connected Via Anyconnect Full tunnel
I am trying ssh from PC connected to inside interface to switch connected to intterface MGMT_WLC
From firewall i can ping ip 10.31.2.34 but from PC ping does not work.
Jun 28 2015 09:04:38: %ASA-6-302013: Built outbound TCP connection 212386 for MGMT_WLC:10.31.2.34/22 (10.31.2.34/22) to inside:10.0.0.15/61436 (10.0.0.15/61436)
My ASA version is 9.1
Need to know what NAT config i need to allow ssh from host behind inside interface to switch connected to MGMT_WLC interface of ASA?
Mahesh
Solved! Go to Solution.
06-28-2015 10:32 AM
Mahesh,
In the absence of any NAT statement having been defined, ASA 9.1 will not NAT the addresses.
Can you check the ssh flow in packet-tracer? That will inject an artificial packet into the data plane and tell us how the ASA will handle them.
Assuming your PC is at 10.0.0.15 and trying to ssh to the WLC interface at 10.31.2.34, the syntax would be:
packet-tracer input inside tcp 10.0.0.15 1025 10.31.2.34 22
06-28-2015 10:32 AM
Mahesh,
06-28-2015 11:14 AM
Hi Marvin,
Here is output
pri/act/ASA1# packet-tracer input inside tcp 10.0.0.10 1025 10.31.2.34 22
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in 10.31.2.0 255.255.255.0 MGMT_WLC
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group inside_access_in in interface inside
access-list inside_access_in extended permit tcp 10.0.0.0 255.255.255.0 host 10.31.2.34 eq ssh
Phase: 3
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: FOVER
Subtype: standby-update
Result: ALLOW
Config:
Phase: 6
Type: NAT
Result: ALLOW
Config:
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 8
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 216707, packet dispatched to next module
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: MGMT_WLC
output-status: up
output-line-status: up
Action: allow
log shows
Jun 28 2015 12:07:28: %ASA-6-302013: Built outbound TCP connection 216703 for MGMT_WLC:10.31.2.34/22 (10.31.2.34/22) to inside:10.0.0.10/52553 (10.0.0.10/52553)
Jun 28 2015 12:07:58: %ASA-6-302014: Teardown TCP connection 216703 for MGMT_WLC:10.31.2.34/22 to inside:10.0.0.10/52553 duration 0:00:30 bytes 0 SYN Timeout
Seems there was no route from switch to subnet 10.0.0.0.
I added the static route and it is working now.
Best regards
MAhesh
06-28-2015 12:22 PM
Great - problem solved and it was not the firewall. :)
Thanks for the rating.
Best regards,
- Marvin
