06-29-2015 02:16 AM - edited 07-05-2021 03:28 AM
i want to monitor cisco access point using SNMP .These WAP are controlled by two Cisco Controllers (In HA mode ‘Active/Passive)and the protocol used for Controller-WAP communication is CAPWAP . Is that possible or not
Somtehin Else can we find an OID or monitor which can calculate signal strength (Weakness) on cisco Controllere wireless or access points ?
Ahmed
06-29-2015 02:49 AM
Yes you can. SNMP is the underlying protocol used by Cisco Prime Infrastructre.
Exactly WHAT are you trying to do/achieve?
06-29-2015 03:30 AM
HI
I would like to supervise the access points and the controller by monitoring application and I would like to know how to enable snmp in the access points(for the case of capwap AP) is that through the controller or independently whether the WLC contains the OID of signal strength (Weakness)
