06-29-2015 02:06 PM - edited 03-17-2019 03:30 AM
I am trying to get my 3824 CME 8.6 to work as a gateway between Lync 2013 and SIP.US SIP Trunk. I can see the calls coming into the CME router from both sides but the calls never complete either outbound or inbound.
Any assistance would be appreciated.
Below is the relevant configuration
voice service voip
ip address trusted list
ipv4 65.254.44.194
ipv4 74.81.71.18
rtcp keepalive
allow-connections sip to sip
no supplementary-service sip refer
supplementary-service media-renegotiate
sip
min-se 600 session-expires 600
asserted-id pai
midcall-signaling passthru
privacy-policy passthru
privacy-policy send-always
sip-profiles 1
block 181
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice class sip-profiles 1
request INVITE sip-header Expires remove
request INVITE sip-header Session-Expires add "Session-expires: 600"
request INVITE sip-header From modify "<sip:5274388427@72.38.175.1>" "<sip:5274388427@gw1.sip.us>"
voice translation-rule 1
rule 1 /12028883999/ /+12897800001/
rule 2 /\(12028883999\)/ /+\1/
voice translation-rule 2
rule 1 /^.*/ /5274388427/
voice translation-rule 3
rule 1 /\(..........\)/ /+\1/
voice translation-rule 4
voice translation-profile SIP.US-Outgoing
translate calling 5
voice translation-profile toLync
translate called 1
voice translation-profile toPSTN
translate called 2
dial-peer voice 1 voip
description outgoing to Lync
translation-profile outgoing toLync
huntstop
rtp payload-type comfort-noise 13
session protocol sipv2
session target ipv4:172.30.32.148:5068
session transport tcp
incoming called-number 12028883999
voice-class codec 1
voice-class sip localhost dns:10.1.1.1
no voice-class sip early-offer forced
no voice-class sip block 183
no voice-class sip block 181
voice-class sip options-keepalive
dtmf-relay rtp-nte
dial-peer voice 2 voip
description **Outgoing Calls to SIP.US SIP Trunk**
translation-profile outgoing toPSTN
destination-pattern +1..........$
session target dns:gw1.sip.us
voice-class sip dtmf-relay force rtp-nte
voice-class sip profiles 1
dtmf-relay rtp-nte
codec g711ulaw
no vad
authentication username 5274388 password 7 PASS realm gw1.sip.us
sip-ua
credentials username 5274388 password 7 PASS realm gw1.sip.us
retry invite 2
retry register 10
timers connect 100
registrar 1 dns:gw1.sip.us expires 360 refresh-ratio 20 auth-realm gw1.sip.us
06-29-2015 02:47 PM
Hello
Can you please post the debug which you have collected
debug ccsip messages
debug voice ccapi inout
Br,
Nadeem
06-29-2015 03:04 PM
Here is the debug - Call from Lync client to PSTN
*Jun 29 22:52:36.802: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:+12899621735@10.1.1.1;user=phone SIP/2.0
FROM: "timd"<sip:+12897800001@sfb.ms;user=phone>;epid=6852673752;tag=4d5c45ad99
TO: <sip:+12899621735@10.1.1.1;user=phone>
CSEQ: 478 INVITE
CALL-ID: bae3334c-c821-426c-911c-b10ec15a17ea
MAX-FORWARDS: 70
VIA: SIP/2.0/TCP 172.30.200.4:53351;branch=z9hG4bK69ec17db
CONTACT: <sip:sfbfe01.sfb.ms:5068;transport=Tcp;maddr=172.30.200.4;ms-opaque=5c837fbabb507d77>
CONTENT-LENGTH: 339
SUPPORTED: 100rel
USER-AGENT: RTCC/6.0.0.0 MediationServer
CONTENT-TYPE: application/sdp
ALLOW: ACK
Allow: CANCEL,BYE,INVITE,PRACK,UPDATE
v=0
o=- 16 1 IN IP4 172.30.200.4
s=session
c=IN IP4 172.30.200.4
b=CT:1000
t=0 0
m=audio 50136 RTP/AVP 97 101 13 0 8
a=rtcp:50137
a=label:Audio
a=sendrecv
a=rtpmap:97 RED/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:13 CN/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=ptime:20
*Jun 29 22:52:36.810: //-1/5EFF1E058F85/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=+12897800001
----- ccCallInfo IE subfields -----
cisco-ani=+12897800001
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=+12899621735
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
*Jun 29 22:52:36.810: //-1/5EFF1E058F85/CCAPI/cc_api_call_setup_ind_common:
Interface=0x70910304, Call Info(
Calling Number=+12897800001,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=+12899621735(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=2, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1831
*Jun 29 22:52:36.810: //-1/5EFF1E058F85/CCAPI/ccCheckClipClir:
In: Calling Number=+12897800001(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=+12897800001(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*Jun 29 22:52:36.810: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jun 29 22:52:36.810: :cc_get_feature_vsa malloc success
*Jun 29 22:52:36.810: cc_get_feature_vsa count is 1
*Jun 29 22:52:36.810: :FEATURE_VSA attributes are: feature_name:0,feature_time:1931238112,feature_id:792
*Jun 29 22:52:36.810: //1831/5EFF1E058F85/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=+12897800001(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=+12899621735(TON=Unknown, NPI=Unknown))
*Jun 29 22:52:36.810: //1831/5EFF1E058F85/CCAPI/cc_process_call_setup_ind:
Event=0x6B6CFD18
*Jun 29 22:52:36.810: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number +12899621735
*Jun 29 22:52:36.810: //1831/5EFF1E058F85/CCAPI/ccCallSetContext:
Context=0xC191F2D0
>>>>CCAPI handed cid 1831 with tag 2 to app "_ManagedAppProcess_Default"
*Jun 29 22:52:36.814: //1831/5EFF1E058F85/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 172.30.200.4:53351;branch=z9hG4bK69ec17db;received=172.30.32.148
From: "timd"<sip:+12897800001@sfb.ms;user=phone>;epid=6852673752;tag=4d5c45ad99
To: <sip:+12899621735@10.1.1.1;user=phone>
Date: Mon, 29 Jun 2015 22:52:36 GMT
Call-ID: bae3334c-c821-426c-911c-b10ec15a17ea
CSeq: 478 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
*Jun 29 22:52:36.814: //1831/5EFF1E058F85/CCAPI/ccCallProceeding:
*Jun 29 22:52:36.814: //1831/5EFF1E058F85/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=2, Params=0xC1923160, Progress Indication=NULL(0)
*Jun 29 22:52:36.814: //1831/5EFF1E058F85/CCAPI/ccCheckClipClir:
Destination Pattern=+1..........$, Called Number=5274388427, Digit Strip=FALSE
Called Number=5274388427(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=timd
Account Number=+12897800001, Final Destination Flag=TRUE,
Guid=5EFF1E05-1DE8-11E5-8F85-C02C356D7D52, Outgoing Dial-peer=2
*Jun 29 22:52:36.814: //1831/5EFF1E058F85/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=5274388427
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Jun 29 22:52:36.814: //1831/5EFF1E058F85/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x70910304, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=+12897800001,(Calling Name=timd)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=5274388427(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Jun 29 22:52:36.814: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jun 29 22:52:36.814: :cc_get_feature_vsa malloc success
*Jun 29 22:52:36.814: cc_get_feature_vsa count is 2
*Jun 29 22:52:36.814: :FEATURE_VSA attributes are: feature_name:0,feature_time:1931237664,feature_id:793
*Jun 29 22:52:36.814: //1832/5EFF1E058F85/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
*Jun 29 22:52:36.814: //1832/5EFF1E058F85/CCAPI/ccCallSetContext:
Context=0xC1923110
*Jun 29 22:52:36.814: //1831/5EFF1E058F85/CCAPI/ccSaveDialpeerTag:
*Jun 29 22:52:36.818: //1832/5EFF1E058F85/CCAPI/cc_api_call_proceeding:
Interface=0x70910304, Progress Indication=NULL(0)
*Jun 29 22:52:36.858: //1832/5EFF1E058F85/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:5274388427@gw1.sip.us:5060 SIP/2.0
Via: SIP/2.0/UDP 72.38.175.138:5060;branch=z9hG4bK44A688
From: "timd" <sip:+12897800001@72.38.175.138>;tag=157467C-9C0
To: <sip:5274388427@gw1.sip.us>
Call-ID: 5F00F27D-1DE811E5-8F8BC02C-356D7D52@72.38.175.138
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE: 600
Cisco-Guid: 1593777669-0501748197-2407907372-0896367954
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1435618356
Contact: <sip:+12897800001@72.38.175.138:5060>
Max-Forwards: 69
P-Asserted-Identity: "timd" <sip:+12897800001@72.38.175.138>
Privacy: none
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 6403 3176 IN IP4 72.38.175.138
s=SIP Call
c=IN IP4 72.38.175.138
t=0 0
m=audio 17910 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
*Jun 29 22:52:36.898: //1832/5EFF1E058F85/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Received:
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/UDP 72.38.175.138:5060;branch=z9hG4bK44A688;rport=56422
To: <sip:5274388427@gw1.sip.us>;tag=2484f1a5f06b7307c34ab1dd8d74150a.76d1
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="gw1.sip.us", nonce="VZHBT1WRvvdkRH1GnUL7ZxdHYnRSwF+G7/jZGqxBeNjBCziLVlfP8B/hRmzC", qop="auth"
Content-Length: 0
*Jun 29 22:52:36.898: //1832/5EFF1E058F85/CCAPI/cc_api_call_disconnected:
Cause Value=47, Interface=0x70910304, Call Id=1832
Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
*Jun 29 22:52:36.898: //1831/5EFF1E058F85/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
*Jun 29 22:52:36.898: //1832/5EFF1E058F85/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=1832
*Jun 29 22:52:36.898: //1832/5EFF1E058F85/CCAPI/ccCallDisconnect:
Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=47)
Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
*Jun 29 22:52:36.898: //1832/5EFF1E058F85/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x70910304, Tag=0x0, Call Id=1832,
Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
*Jun 29 22:52:36.902: //1832/5EFF1E058F85/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
*Jun 29 22:52:36.902: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jun 29 22:52:36.902: :cc_free_feature_vsa freeing 731C5918
*Jun 29 22:52:36.902: vsacount in free is 1
*Jun 29 22:52:36.902: //1831/5EFF1E058F85/CCAPI/ccCallDisconnect:
Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
*Jun 29 22:52:36.902: //1831/5EFF1E058F85/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
To: <sip:+12899621735@10.1.1.1;user=phone>;tag=15746AC-1BB9
CSeq: 478 INVITE
Reason: Q.850;cause=47
Content-Length: 0
*Jun 29 22:52:36.902: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:5274388427@gw1.sip.us:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Privacy: none
Content-Length: 0
*Jun 29 22:52:36.906: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:+12899621735@10.1.1.1;user=phone SIP/2.0
FROM: "timd"<sip:+12897800001@sfb.ms;user=phone>;tag=4d5c45ad99;epid=6852673752
TO: <sip:+12899621735@10.1.1.1;user=phone>;tag=15746AC-1BB9
CSEQ: 478 ACK
MAX-FORWARDS: 70
CONTENT-LENGTH: 0
*Jun 29 22:52:36.906: //1831/5EFF1E058F85/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x70910304, Tag=0x0, Call Id=1831,
*Jun 29 22:52:36.906: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jun 29 22:52:36.906: :cc_free_feature_vsa freeing 731C5AD8
*Jun 29 22:52:36.906: vsacount in free is 0
*Jun 29 22:52:41.606: //1833/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
OPTIONS sip:172.30.32.148:5068 SIP/2.0
Via: SIP/2.0/TCP 10.1.1.1:5060;branch=z9hG4bK44BA9
To: <sip:172.30.32.148>
Date: Mon, 29 Jun 2015 22:52:41 GMT
Call-ID: 61DB8A8B-1DE811E5-8F8CC02C-356D7D52@10.1.1.1
Max-Forwards: 70
CSeq: 101 OPTIONS
Contact: <sip:10.1.1.1:5060;transport=tcp>
Content-Length: 0
*Jun 29 22:52:41.610: //1833/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
TO: <sip:172.30.32.148>;tag=60b24e6745
CSEQ: 101 OPTIONS
CALL-ID: 61DB8A8B-1DE811E5-8F8CC02C-356D7D52@10.1.1.1
VIA: SIP/2.0/TCP 10.1.1.1:5060;branch=z9hG4bK44BA9
ACCEPT: application/sdp
CONTENT-LENGTH: 0
ACCEPT-ENCODING: gzip
ACCEPT-LANGUAGE: en
ALLOW: NOTIFY
ALLOW: BENOTIFY
SERVER: RTCC/6.0.0.0 MediationServer
Call from PSTN to Lync
INVITE sip:17702586200@72.38.175.138:5060 SIP/2.0
Record-Route: <sip:65.254.44.194;lr=on;ftag=gK04252e84;vsf=AAAAABkJCwEPCwcFAgJzA3cYBR0DHQQABB8BMTA-;dlgcor=c6f.efc2>
Via: SIP/2.0/UDP 65.254.44.194;branch=z9hG4bKbc6f.1a869bb9044822c3bbcf37c6d193f1a6.0
Via: SIP/2.0/UDP 67.231.5.110:5060;branch=z9hG4bK04B3b09c62f95c38ff4
From: "BURLINGTON ON " <sip:2899621735@67.231.5.110>;tag=gK04252e84
To: <sip:+17702586200@65.254.44.194>
Call-ID: 1124339474_33355707@67.231.5.110
CSeq: 578766409 INVITE
Max-Forwards: 32
Allow: INVITE,ACK,CANCEL,BYE,OPTIONS
Accept: application/sdp
Contact: "TIMOTHY DAY" <sip:+12899621735@67.231.5.110:5060>
Supported: precondition,replaces
Content-Length: 332
Content-Disposition: session; handling=required
Privacy: off
v=0
o=Sonus_UAC 567290618 821478773 IN IP4 67.231.5.110
s=SIP Media Capabilities
c=IN IP4 67.231.5.75
t=0 0
m=audio 17246 RTP/AVP 0 18 96 101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:96 iLBC/8000
a=fmtp:96 mode=30
a=fmtp:101 0-15
a=sendrecv
a=ptime:30
*Jun 29 22:59:16.754: //-1/4D61B97390B1/CCAPI/cc_api_display_ie_subfields:
cisco-username=2899621735
cisco-ani=2899621735
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=17702586200
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Jun 29 22:59:16.754: //-1/4D61B97390B1/CCAPI/cc_api_call_setup_ind_common:
Calling Number=2899621735,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=17702586200(TON=Unknown, NPI=Unknown),
Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1908
*Jun 29 22:59:16.754: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jun 29 22:59:16.754: :cc_get_feature_vsa malloc success
*Jun 29 22:59:16.754: cc_get_feature_vsa count is 1
*Jun 29 22:59:16.754: :FEATURE_VSA attributes are: feature_name:0,feature_time:1931237664,feature_id:850
*Jun 29 22:59:16.754: //1908/4D61B97390B1/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=2899621735(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=17702586200(TON=Unknown, NPI=Unknown))
*Jun 29 22:59:16.754: //1908/4D61B97390B1/CCAPI/cc_process_call_setup_ind:
Event=0x6B6CF220
*Jun 29 22:59:16.754: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 17702586200
*Jun 29 22:59:16.754: //1908/4D61B97390B1/CCAPI/ccCallSetContext:
Context=0xC1920790
>>>>CCAPI handed cid 1908 with tag 0 to app "_ManagedAppProcess_Default"
*Jun 29 22:59:16.754: //1908/4D61B97390B1/CCAPI/ccCallProceeding:
*Jun 29 22:59:16.758: //1908/4D61B97390B1/CCAPI/ccCallDisconnect:
Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
*Jun 29 22:59:16.758: //1908/4D61B97390B1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 65.254.44.194;branch=z9hG4bKbc6f.1a869bb9044822c3bbcf37c6d193f1a6.0,SIP/2.0/UDP 67.231.5.110:5060;branch=z9hG4bK04B3b09c62f95c38ff4
Date: Mon, 29 Jun 2015 22:59:16 GMT
Content-Length: 0
Sent:
SIP/2.0 404 Not Found
To: <sip:+17702586200@65.254.44.194>;tag=15D609C-1716
Reason: Q.850;cause=1
Content-Length: 0
*Jun 29 22:59:16.798: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:17702586200@72.38.175.138:5060 SIP/2.0
CSeq: 578766409 ACK
Max-Forwards: 32
Content-Length: 0
*Jun 29 22:59:16.798: //1908/4D61B97390B1/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x70910304, Tag=0x0, Call Id=1908,
Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
*Jun 29 22:59:16.798: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jun 29 22:59:16.798: :cc_free_feature_vsa freeing 731C5918
*Jun 29 22:59:16.798: vsacount in free is 0
*Jun 29 22:59:17.458: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Record-Route: <sip:74.81.71.18;lr=on;ftag=gK00795e5b;vsf=AAAAABkJCwEPCwcFAgJzA3cYBR0DHQQABB8BMTA-;dlgcor=a69.65d>
Via: SIP/2.0/UDP 74.81.71.18;branch=z9hG4bK049d.d9ae0fda40d7f875509c9a6f6e5048c9.0
Via: SIP/2.0/UDP 67.231.5.110:5060;branch=z9hG4bK00Be316d0fb16c95e56
From: "BURLINGTON ON " <sip:2899621735@67.231.5.110>;tag=gK00795e5b
To: <sip:+17702586200@74.81.71.18>
Call-ID: 1124113896_30329736@67.231.5.110
CSeq: 934374746 INVITE
Max-Forwards: 32
Content-Length: 334
Privacy: off
v=0
o=Sonus_UAC 1369885266 1527579148 IN IP4 67.231.5.110
t=0 0
m=audio 23536 RTP/AVP 0 18 96 101
a=fmtp:18 annexb=no
a=fmtp:96 mode=30
a=fmtp:101 0-15
a=sendrecv
a=ptime:30
*Jun 29 22:59:17.462: //-1/4DCDC29890B6/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=17702586200
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Jun 29 22:59:17.462: //-1/4DCDC29890B6/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1909
*Jun 29 22:59:17.462: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jun 29 22:59:17.462: :cc_get_feature_vsa malloc success
*Jun 29 22:59:17.462: cc_get_feature_vsa count is 1
*Jun 29 22:59:17.462: :FEATURE_VSA attributes are: feature_name:0,feature_time:1931237664,feature_id:851
*Jun 29 22:59:17.462: //1909/4DCDC29890B6/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*Jun 29 22:59:17.462: //1909/4DCDC29890B6/CCAPI/cc_process_call_setup_ind:
Event=0x6B6CF220
*Jun 29 22:59:17.462: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Jun 29 22:59:17.462: //1909/4DCDC29890B6/CCAPI/ccCallSetContext:
Context=0xC1921C50
>>>>CCAPI handed cid 1909 with tag 0 to app "_ManagedAppProcess_Default"
*Jun 29 22:59:17.466: //1909/4DCDC29890B6/CCAPI/ccCallProceeding:
*Jun 29 22:59:17.466: //1909/4DCDC29890B6/CCAPI/ccCallDisconnect:
*Jun 29 22:59:17.466: //1909/4DCDC29890B6/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 74.81.71.18;branch=z9hG4bK049d.d9ae0fda40d7f875509c9a6f6e5048c9.0,SIP/2.0/UDP 67.231.5.110:5060;branch=z9hG4bK00Be316d0fb16c95e56
Date: Mon, 29 Jun 2015 22:59:17 GMT
Content-Length: 0
Sent:
To: <sip:+17702586200@74.81.71.18>;tag=15D6360-26B1
Content-Length: 0
*Jun 29 22:59:17.514: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 934374746 ACK
Max-Forwards: 32
Content-Length: 0
*Jun 29 22:59:17.514: //1909/4DCDC29890B6/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x70910304, Tag=0x0, Call Id=1909,
*Jun 29 22:59:17.514: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jun 29 22:59:17.514: :cc_free_feature_vsa freeing 731C5918
*Jun 29 22:59:17.514: vsacount in free is 0
*Jun 29 22:59:17.654: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Record-Route: <sip:65.254.44.194;lr=on;ftag=gK0442ec2d;vsf=AAAAABkJCwEPCwcFAgJzA3cYBR0DHQAAAB8BMTA-;dlgcor=693.6b7>
Via: SIP/2.0/UDP 65.254.44.194;branch=z9hG4bKfeec.69d577020f02c84da09a87ba1fb51418.0
Via: SIP/2.0/UDP 67.231.1.110:5060;branch=z9hG4bK04B1fef7b2acb3aaff6
From: "BURLINGTON ON " <sip:2899621735@67.231.1.110>;tag=gK0442ec2d
Call-ID: 939820466_127863056@67.231.1.110
CSeq: 1426099632 INVITE
Max-Forwards: 32
Contact: "TIMOTHY DAY" <sip:+12899621735@67.231.1.110:5060>
Content-Length: 334
Privacy: off
v=0
o=Sonus_UAC 1180871992 1988229548 IN IP4 67.231.1.110
c=IN IP4 67.231.1.76
t=0 0
m=audio 11228 RTP/AVP 0 18 96 101
a=fmtp:18 annexb=no
a=fmtp:96 mode=30
a=fmtp:101 0-15
a=sendrecv
a=ptime:30
*Jun 29 22:59:17.658: //-1/4DEBAA6B90BB/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=17702586200
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Jun 29 22:59:17.658: //-1/4DEBAA6B90BB/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1910
*Jun 29 22:59:17.658: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jun 29 22:59:17.658: :cc_get_feature_vsa malloc success
*Jun 29 22:59:17.658: cc_get_feature_vsa count is 1
*Jun 29 22:59:17.658: :FEATURE_VSA attributes are: feature_name:0,feature_time:1931237664,feature_id:852
*Jun 29 22:59:17.658: //1910/4DEBAA6B90BB/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*Jun 29 22:59:17.658: //1910/4DEBAA6B90BB/CCAPI/cc_process_call_setup_ind:
Event=0x6B6CF220
*Jun 29 22:59:17.658: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Jun 29 22:59:17.658: //1910/4DEBAA6B90BB/CCAPI/ccCallSetContext:
Context=0xC1923110
>>>>CCAPI handed cid 1910 with tag 0 to app "_ManagedAppProcess_Default"
*Jun 29 22:59:17.658: //1910/4DEBAA6B90BB/CCAPI/ccCallProceeding:
*Jun 29 22:59:17.662: //1910/4DEBAA6B90BB/CCAPI/ccCallDisconnect:
*Jun 29 22:59:17.662: //1910/4DEBAA6B90BB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 65.254.44.194;branch=z9hG4bKfeec.69d577020f02c84da09a87ba1fb51418.0,SIP/2.0/UDP 67.231.1.110:5060;branch=z9hG4bK04B1fef7b2acb3aaff6
Content-Length: 0
Sent:
To: <sip:+17702586200@65.254.44.194>;tag=15D6424-1DCA
Content-Length: 0
*Jun 29 22:59:17.702: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1426099632 ACK
Max-Forwards: 32
Content-Length: 0
*Jun 29 22:59:17.702: //1910/4DEBAA6B90BB/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x70910304, Tag=0x0, Call Id=1910,
*Jun 29 22:59:17.702: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jun 29 22:59:17.702: :cc_free_feature_vsa freeing 731C5918
*Jun 29 22:59:17.702: vsacount in free is 0
*Jun 29 22:59:18.358: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Record-Route: <sip:74.81.71.18;lr=on;ftag=gK082be3ae;vsf=AAAAABkJCwEPCwcFAgJzA3cYBR0DHQAAAB8BMTA-;dlgcor=ab3.68b1>
Via: SIP/2.0/UDP 74.81.71.18;branch=z9hG4bKa8a6.33aba778f20a19afcbbb1ff4ee3f044a.0
Via: SIP/2.0/UDP 67.231.1.110:5060;branch=z9hG4bK08Bec0676800866cdf3
From: "BURLINGTON ON " <sip:2899621735@67.231.1.110>;tag=gK082be3ae
Call-ID: 940063946_116205979@67.231.1.110
CSeq: 272480680 INVITE
Max-Forwards: 32
Content-Length: 332
Privacy: off
v=0
o=Sonus_UAC 1691140210 287773435 IN IP4 67.231.1.110
c=IN IP4 67.231.1.75
t=0 0
m=audio 9534 RTP/AVP 0 18 96 101
a=fmtp:18 annexb=no
a=fmtp:96 mode=30
a=fmtp:101 0-15
a=sendrecv
a=ptime:30
*Jun 29 22:59:18.362: //-1/4E5716CF90C0/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=17702586200
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Jun 29 22:59:18.362: //-1/4E5716CF90C0/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1911
*Jun 29 22:59:18.362: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jun 29 22:59:18.362: :cc_get_feature_vsa malloc success
*Jun 29 22:59:18.362: cc_get_feature_vsa count is 1
*Jun 29 22:59:18.362: :FEATURE_VSA attributes are: feature_name:0,feature_time:1931237664,feature_id:853
*Jun 29 22:59:18.362: //1911/4E5716CF90C0/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*Jun 29 22:59:18.362: //1911/4E5716CF90C0/CCAPI/cc_process_call_setup_ind:
Event=0x6B6CF220
*Jun 29 22:59:18.362: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Jun 29 22:59:18.362: //1911/4E5716CF90C0/CCAPI/ccCallSetContext:
Context=0xC191F2D0
>>>>CCAPI handed cid 1911 with tag 0 to app "_ManagedAppProcess_Default"
*Jun 29 22:59:18.362: //1911/4E5716CF90C0/CCAPI/ccCallProceeding:
*Jun 29 22:59:18.366: //1911/4E5716CF90C0/CCAPI/ccCallDisconnect:
*Jun 29 22:59:18.366: //1911/4E5716CF90C0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 74.81.71.18;branch=z9hG4bKa8a6.33aba778f20a19afcbbb1ff4ee3f044a.0,SIP/2.0/UDP 67.231.1.110:5060;branch=z9hG4bK08Bec0676800866cdf3
Date: Mon, 29 Jun 2015 22:59:18 GMT
Content-Length: 0
Sent:
To: <sip:+17702586200@74.81.71.18>;tag=15D66E4-25A7
Content-Length: 0
*Jun 29 22:59:18.414: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 272480680 ACK
Max-Forwards: 32
Content-Length: 0
*Jun 29 22:59:18.414: //1911/4E5716CF90C0/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x70910304, Tag=0x0, Call Id=1911,
*Jun 29 22:59:18.414: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jun 29 22:59:18.414: :cc_free_feature_vsa freeing 731C5918
*Jun 29 22:59:18.414: vsacount in free is 0
*Jun 29 22:59:19.454: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Record-Route: <sip:65.254.44.194;lr=on;ftag=gK0849f541;vsf=AAAAABkJCwEPCwcFAgJzA3cYBR0DHQQABB8BMTA-;dlgcor=44.a842>
Via: SIP/2.0/UDP 65.254.44.194;branch=z9hG4bKf8d4.c6ed5a352f75fcaf6bec8b874e96608b.0
Via: SIP/2.0/UDP 67.231.5.110:5060;branch=z9hG4bK08Ba3f6e2bf34886f70
From: "BURLINGTON ON " <sip:2899621735@67.231.5.110>;tag=gK0849f541
Call-ID: 1124632352_63436725@67.231.5.110
CSeq: 1060170867 INVITE
Max-Forwards: 32
Contact: <sip:+12899621735@67.231.5.110:5060>
Content-Length: 333
Privacy: off
v=0
o=Sonus_UAC 1267462592 720579377 IN IP4 67.231.5.110
c=IN IP4 67.231.5.76
t=0 0
m=audio 37122 RTP/AVP 0 18 96 101
a=fmtp:18 annexb=no
a=fmtp:96 mode=30
a=fmtp:101 0-15
a=sendrecv
a=ptime:30
*Jun 29 22:59:19.462: //-1/4EFEEF9890C5/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=17702586200
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Jun 29 22:59:19.462: //-1/4EFEEF9890C5/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1912
*Jun 29 22:59:19.462: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jun 29 22:59:19.462: :cc_get_feature_vsa malloc success
*Jun 29 22:59:19.462: cc_get_feature_vsa count is 1
*Jun 29 22:59:19.462: :FEATURE_VSA attributes are: feature_name:0,feature_time:1931237664,feature_id:854
*Jun 29 22:59:19.462: //1912/4EFEEF9890C5/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*Jun 29 22:59:19.462: //1912/4EFEEF9890C5/CCAPI/cc_process_call_setup_ind:
Event=0x6B6CF220
*Jun 29 22:59:19.462: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Jun 29 22:59:19.462: //1912/4EFEEF9890C5/CCAPI/ccCallSetContext:
Context=0xC19245D0
>>>>CCAPI handed cid 1912 with tag 0 to app "_ManagedAppProcess_Default"
*Jun 29 22:59:19.462: //1912/4EFEEF9890C5/CCAPI/ccCallProceeding:
*Jun 29 22:59:19.466: //1912/4EFEEF9890C5/CCAPI/ccCallDisconnect:
*Jun 29 22:59:19.466: //1912/4EFEEF9890C5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 65.254.44.194;branch=z9hG4bKf8d4.c6ed5a352f75fcaf6bec8b874e96608b.0,SIP/2.0/UDP 67.231.5.110:5060;branch=z9hG4bK08Ba3f6e2bf34886f70
Date: Mon, 29 Jun 2015 22:59:19 GMT
Content-Length: 0
Sent:
To: <sip:+17702586200@65.254.44.194>;tag=15D6B30-166A
Content-Length: 0
*Jun 29 22:59:19.506: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1060170867 ACK
Max-Forwards: 32
Content-Length: 0
*Jun 29 22:59:19.510: //1912/4EFEEF9890C5/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x70910304, Tag=0x0, Call Id=1912,
*Jun 29 22:59:19.510: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jun 29 22:59:19.510: :cc_free_feature_vsa freeing 731C5918
*Jun 29 22:59:19.510: vsacount in free is 0
*Jun 29 22:59:19.586: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.1.1.1 SIP/2.0
FROM: <sip:sfbfe01.sfb.ms:5068;transport=Tcp;ms-opaque=5c837fbabb507d77>;epid=6852673752;tag=e8b135b5da
TO: <sip:10.1.1.1>
CSEQ: 485 OPTIONS
CALL-ID: 482950cb8cdb463593985aa5b1274d62
MAX-FORWARDS: 70
VIA: SIP/2.0/TCP 172.30.200.4:53377;branch=z9hG4bKb46f9788
CONTACT: <sip:sfbfe01.sfb.ms:5068;transport=Tcp;maddr=172.30.200.4>
CONTENT-LENGTH: 0
*Jun 29 22:59:19.646: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/TCP 172.30.200.4:53377;branch=z9hG4bKb46f9788;received=172.30.32.148
From: <sip:sfbfe01.sfb.ms:5068;transport=Tcp;ms-opaque=5c837fbabb507d77>;epid=6852673752;tag=e8b135b5da
To: <sip:10.1.1.1>;tag=15D6BAC-1D9D
Call-ID: 482950cb8cdb463593985aa5b1274d62
CSeq: 485 OPTIONS
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Length: 157
v=0
o=CiscoSystemsSIP-GW-UserAgent 8360 9795 IN IP4 10.1.1.1
s=SIP Call
c=IN IP4 10.1.1.1
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
c=IN IP4 10.1.1.1
*Jun 29 22:59:20.242: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Record-Route: <sip:74.81.71.18;lr=on;ftag=gK04258ba4;vsf=AAAAABkJCwEPCwcFAgJzA3cYBR0DHQQABB8BMTA-;dlgcor=ecc.03c>
Via: SIP/2.0/UDP 74.81.71.18;branch=z9hG4bKcc1b.33236fdb8374359c85ba430207fd340b.0
Via: SIP/2.0/UDP 67.231.5.110:5060;branch=z9hG4bK04B3b818a70c5bc2256
From: "BURLINGTON ON " <sip:2899621735@67.231.5.110>;tag=gK04258ba4
Call-ID: 1124339521_134130425@67.231.5.110
CSeq: 1192119143 INVITE
Max-Forwards: 32
Content-Length: 333
Privacy: off
v=0
o=Sonus_UAC 293648397 1600291044 IN IP4 67.231.5.110
t=0 0
m=audio 64236 RTP/AVP 0 18 96 101
a=fmtp:18 annexb=no
a=fmtp:96 mode=30
a=fmtp:101 0-15
a=sendrecv
a=ptime:30
*Jun 29 22:59:20.246: //-1/4F7690E690CB/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=17702586200
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Jun 29 22:59:20.246: //-1/4F7690E690CB/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1914
*Jun 29 22:59:20.246: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jun 29 22:59:20.246: :cc_get_feature_vsa malloc success
*Jun 29 22:59:20.246: cc_get_feature_vsa count is 1
*Jun 29 22:59:20.246: :FEATURE_VSA attributes are: feature_name:0,feature_time:1931237664,feature_id:855
*Jun 29 22:59:20.250: //1914/4F7690E690CB/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*Jun 29 22:59:20.250: //1914/4F7690E690CB/CCAPI/cc_process_call_setup_ind:
Event=0x6B6CF220
*Jun 29 22:59:20.250: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Jun 29 22:59:20.250: //1914/4F7690E690CB/CCAPI/ccCallSetContext:
Context=0xC1925A90
>>>>CCAPI handed cid 1914 with tag 0 to app "_ManagedAppProcess_Default"
*Jun 29 22:59:20.250: //1914/4F7690E690CB/CCAPI/ccCallProceeding:
*Jun 29 22:59:20.250: //1914/4F7690E690CB/CCAPI/ccCallDisconnect:
*Jun 29 22:59:20.254: //1914/4F7690E690CB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 74.81.71.18;branch=z9hG4bKcc1b.33236fdb8374359c85ba430207fd340b.0,SIP/2.0/UDP 67.231.5.110:5060;branch=z9hG4bK04B3b818a70c5bc2256
Date: Mon, 29 Jun 2015 22:59:20 GMT
Content-Length: 0
Sent:
To: <sip:+17702586200@74.81.71.18>;tag=15D6E40-26FB
Content-Length: 0
*Jun 29 22:59:20.306: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1192119143 ACK
Max-Forwards: 32
Content-Length: 0
*Jun 29 22:59:20.306: //1914/4F7690E690CB/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x70910304, Tag=0x0, Call Id=1914,
*Jun 29 22:59:20.306: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jun 29 22:59:20.306: :cc_free_feature_vsa freeing 731C5918
*Jun 29 22:59:20.306: vsacount in free is 0
*Jun 29 22:59:21.106: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Record-Route: <sip:65.254.44.194;lr=on;ftag=gK04432635;vsf=AAAAABkJCwEPCwcFAgJzA3cYBR0DHQAAAB8BMTA-;dlgcor=a05.fb82>
Via: SIP/2.0/UDP 65.254.44.194;branch=z9hG4bKa33b.14f7c1187052af708546cdbd21ba958f.0
Via: SIP/2.0/UDP 67.231.1.110:5060;branch=z9hG4bK04B2034547a590d3673
From: "BURLINGTON ON " <sip:2899621735@67.231.1.110>;tag=gK04432635
Call-ID: 939820496_130012235@67.231.1.110
CSeq: 1989683702 INVITE
Max-Forwards: 32
Contact: <sip:+12899621735@67.231.1.110:5060>
Content-Length: 333
Privacy: off
v=0
o=Sonus_UAC 1540732327 823290702 IN IP4 67.231.1.110
t=0 0
m=audio 37308 RTP/AVP 0 18 96 101
a=fmtp:18 annexb=no
a=fmtp:96 mode=30
a=fmtp:101 0-15
a=sendrecv
a=ptime:30
*Jun 29 22:59:21.110: //-1/4FFA671C90D0/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=17702586200
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Jun 29 22:59:21.114: //-1/4FFA671C90D0/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1915
*Jun 29 22:59:21.114: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jun 29 22:59:21.114: :cc_get_feature_vsa malloc success
*Jun 29 22:59:21.114: cc_get_feature_vsa count is 1
*Jun 29 22:59:21.114: :FEATURE_VSA attributes are: feature_name:0,feature_time:1931237664,feature_id:856
*Jun 29 22:59:21.114: //1915/4FFA671C90D0/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*Jun 29 22:59:21.114: //1915/4FFA671C90D0/CCAPI/cc_process_call_setup_ind:
Event=0x6B6CF220
*Jun 29 22:59:21.114: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Jun 29 22:59:21.114: //1915/4FFA671C90D0/CCAPI/ccCallSetContext:
Context=0xC19298D0
>>>>CCAPI handed cid 1915 with tag 0 to app "_ManagedAppProcess_Default"
*Jun 29 22:59:21.154: //1915/4FFA671C90D0/CCAPI/ccCallProceeding:
*Jun 29 22:59:21.154: //1915/4FFA671C90D0/CCAPI/ccCallDisconnect:
*Jun 29 22:59:21.158: //1915/4FFA671C90D0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 65.254.44.194;branch=z9hG4bKa33b.14f7c1187052af708546cdbd21ba958f.0,SIP/2.0/UDP 67.231.1.110:5060;branch=z9hG4bK04B2034547a590d3673
Date: Mon, 29 Jun 2015 22:59:21 GMT
Content-Length: 0
*Jun 29 22:59:21.158: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 32
Content-Length: 333
Privacy: off
v=0
t=0 0
a=fmtp:18 annexb=no
a=fmtp:96 mode=30
a=fmtp:101 0-15
a=sendrecv
a=ptime:30
*Jun 29 22:59:21.162: //1915/4FFA671C90D0/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:+17702586200@65.254.44.194>;tag=15D71CC-1B16
Content-Length: 0
Sent:
Content-Length: 0
*Jun 29 22:59:21.830: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1989683702 ACK
Max-Forwards: 32
Content-Length: 0
*Jun 29 22:59:21.830: //1915/4FFA671C90D0/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x70910304, Tag=0x0, Call Id=1915,
*Jun 29 22:59:21.830: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jun 29 22:59:21.830: :cc_free_feature_vsa freeing 731C5918
*Jun 29 22:59:21.830: vsacount in free is 0
*Jun 29 22:59:21.842: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 32
Content-Length: 0
*Jun 29 22:59:22.318: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Record-Route: <sip:74.81.71.18;lr=on;ftag=gK0443425c;vsf=AAAAABkJCwEPCwcFAgJzA3cYBR0DHQAAAB8BMTA-;dlgcor=9ab.bc72>
Via: SIP/2.0/UDP 74.81.71.18;branch=z9hG4bK66b7.16b7931d6f67d3f342b473f2e5297e5d.0
Via: SIP/2.0/UDP 67.231.1.110:5060;branch=z9hG4bK04B205b36b10cb20fbc
From: "BURLINGTON ON " <sip:2899621735@67.231.1.110>;tag=gK0443425c
Call-ID: 939820511_91987354@67.231.1.110
CSeq: 426813074 INVITE
Max-Forwards: 32
Content-Length: 334
Privacy: off
v=0
o=Sonus_UAC 1502479996 1021725421 IN IP4 67.231.1.110
t=0 0
m=audio 32804 RTP/AVP 0 18 96 101
a=fmtp:18 annexb=no
a=fmtp:96 mode=30
a=fmtp:101 0-15
a=sendrecv
a=ptime:30
*Jun 29 22:59:22.322: //-1/50B356A790D5/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=17702586200
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Jun 29 22:59:22.326: //-1/50B356A790D5/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1916
*Jun 29 22:59:22.326: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jun 29 22:59:22.326: :cc_get_feature_vsa malloc success
*Jun 29 22:59:22.326: cc_get_feature_vsa count is 1
*Jun 29 22:59:22.326: :FEATURE_VSA attributes are: feature_name:0,feature_time:1931237664,feature_id:857
*Jun 29 22:59:22.326: //1916/50B356A790D5/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*Jun 29 22:59:22.326: //1916/50B356A790D5/CCAPI/cc_process_call_setup_ind:
Event=0x6B6CF220
*Jun 29 22:59:22.326: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Jun 29 22:59:22.326: //1916/50B356A790D5/CCAPI/ccCallSetContext:
Context=0xC192AD90
>>>>CCAPI handed cid 1916 with tag 0 to app "_ManagedAppProcess_Default"
*Jun 29 22:59:22.346: //1916/50B356A790D5/CCAPI/ccCallProceeding:
*Jun 29 22:59:22.350: //1916/50B356A790D5/CCAPI/ccCallDisconnect:
*Jun 29 22:59:22.350: //1916/50B356A790D5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 74.81.71.18;branch=z9hG4bK66b7.16b7931d6f67d3f342b473f2e5297e5d.0,SIP/2.0/UDP 67.231.1.110:5060;branch=z9hG4bK04B205b36b10cb20fbc
Date: Mon, 29 Jun 2015 22:59:22 GMT
Content-Length: 0
Sent:
To: <sip:+17702586200@74.81.71.18>;tag=15D7674-1194
Content-Length: 0
*Jun 29 22:59:22.746: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 32
Content-Length: 334
Privacy: off
v=0
t=0 0
a=fmtp:18 annexb=no
a=fmtp:96 mode=30
a=fmtp:101 0-15
a=sendrecv
a=ptime:30
*Jun 29 22:59:22.754: //1916/50B356A790D5/SIP/Msg/ccsipDisplayMsg:
Sent:
Content-Length: 0
*Jun 29 22:59:22.754: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 426813074 ACK
Max-Forwards: 32
Content-Length: 0
*Jun 29 22:59:22.754: //1916/50B356A790D5/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x70910304, Tag=0x0, Call Id=1916,
*Jun 29 22:59:22.754: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jun 29 22:59:22.754: :cc_free_feature_vsa freeing 731C5918
*Jun 29 22:59:22.754: vsacount in free is 0
*Jun 29 22:59:23.338: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 426813074 ACK
Max-Forwards: 32
Content-Length: 0
*Jun 29 22:59:24.366: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Record-Route: <sip:65.254.44.194;lr=on;ftag=gK084a757f;vsf=AAAAABkJCwEPCwcFAgJzA3cYBR0DHQQABB8BMTA-;dlgcor=c81.349>
Via: SIP/2.0/UDP 65.254.44.194;branch=z9hG4bK02a8.ac56dc706101ff87fe0afee36fb56827.0
Via: SIP/2.0/UDP 67.231.5.110:5060;branch=z9hG4bK08Ba4a1c668899911e9
From: "BURLINGTON ON " <sip:2899621735@67.231.5.110>;tag=gK084a757f
Call-ID: 1124632421_109030793@67.231.5.110
CSeq: 2081460007 INVITE
Max-Forwards: 32
Content-Length: 333
Privacy: off
v=0
o=Sonus_UAC 1570630384 834016338 IN IP4 67.231.5.110
t=0 0
m=audio 64608 RTP/AVP 0 18 96 101
a=fmtp:18 annexb=no
a=fmtp:96 mode=30
a=fmtp:101 0-15
a=sendrecv
a=ptime:30
*Jun 29 22:59:24.374: //-1/51EC724790DA/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=17702586200
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Jun 29 22:59:24.374: //-1/51EC724790DA/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1917
*Jun 29 22:59:24.374: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jun 29 22:59:24.374: :cc_get_feature_vsa malloc success
*Jun 29 22:59:24.374: cc_get_feature_vsa count is 1
*Jun 29 22:59:24.374: :FEATURE_VSA attributes are: feature_name:0,feature_time:1931237664,feature_id:858
*Jun 29 22:59:24.374: //1917/51EC724790DA/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*Jun 29 22:59:24.374: //1917/51EC724790DA/CCAPI/cc_process_call_setup_ind:
Event=0x6B6CF220
*Jun 29 22:59:24.374: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Jun 29 22:59:24.374: //1917/51EC724790DA/CCAPI/ccCallSetContext:
Context=0xC1928410
>>>>CCAPI handed cid 1917 with tag 0 to app "_ManagedAppProcess_Default"
*Jun 29 22:59:24.398: //1917/51EC724790DA/CCAPI/ccCallProceeding:
*Jun 29 22:59:24.398: //1917/51EC724790DA/CCAPI/ccCallDisconnect:
*Jun 29 22:59:24.402: //1917/51EC724790DA/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 65.254.44.194;branch=z9hG4bK02a8.ac56dc706101ff87fe0afee36fb56827.0,SIP/2.0/UDP 67.231.5.110:5060;branch=z9hG4bK08Ba4a1c668899911e9
Date: Mon, 29 Jun 2015 22:59:24 GMT
Content-Length: 0
*Jun 29 22:59:24.402: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 32
Content-Length: 333
Privacy: off
v=0
t=0 0
a=fmtp:18 annexb=no
a=fmtp:96 mode=30
a=fmtp:101 0-15
a=sendrecv
a=ptime:30
*Jun 29 22:59:24.406: //1917/51EC724790DA/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:+17702586200@65.254.44.194>;tag=15D7E78-28B
Content-Length: 0
Sent:
Content-Length: 0
*Jun 29 22:59:24.538: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 2081460007 ACK
Max-Forwards: 32
Content-Length: 0
*Jun 29 22:59:24.538: //1917/51EC724790DA/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x70910304, Tag=0x0, Call Id=1917,
*Jun 29 22:59:24.538: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jun 29 22:59:24.538: :cc_free_feature_vsa freeing 731C5918
*Jun 29 22:59:24.538: vsacount in free is 0
Received:
Max-Forwards: 32
Content-Length: 0
*Jun 29 22:59:25.926: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Record-Route: <sip:74.81.71.18;lr=on;ftag=gK084a9176;vsf=AAAAABkJCwEPCwcFAgJzA3cYBR0DHQQABB8BMTA-;dlgcor=95a.7df1>
Via: SIP/2.0/UDP 74.81.71.18;branch=z9hG4bK5664.7c9f9299d883437fed9b5d0d1ae56b70.0
Via: SIP/2.0/UDP 67.231.5.110:5060;branch=z9hG4bK08Ba4c86daabafebcfd
From: "BURLINGTON ON " <sip:2899621735@67.231.5.110>;tag=gK084a9176
Call-ID: 1124632437_40864268@67.231.5.110
CSeq: 1072137542 INVITE
Max-Forwards: 32
Content-Length: 332
Privacy: off
v=0
o=Sonus_UAC 998960821 303189271 IN IP4 67.231.5.110
t=0 0
m=audio 60726 RTP/AVP 0 18 96 101
a=fmtp:18 annexb=no
a=fmtp:96 mode=30
a=fmtp:101 0-15
a=sendrecv
a=ptime:30
*Jun 29 22:59:25.930: //-1/52D9DE6590DF/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=17702586200
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Jun 29 22:59:25.930: //-1/52D9DE6590DF/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1918
*Jun 29 22:59:25.930: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jun 29 22:59:25.930: :cc_get_feature_vsa malloc success
*Jun 29 22:59:25.930: cc_get_feature_vsa count is 1
*Jun 29 22:59:25.930: :FEATURE_VSA attributes are: feature_name:0,feature_time:1931237664,feature_id:859
*Jun 29 22:59:25.930: //1918/52D9DE6590DF/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*Jun 29 22:59:25.934: //1918/52D9DE6590DF/CCAPI/cc_process_call_setup_ind:
Event=0x6B6CF220
*Jun 29 22:59:25.934: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Jun 29 22:59:25.934: //1918/52D9DE6590DF/CCAPI/ccCallSetContext:
Context=0xC192C250
>>>>CCAPI handed cid 1918 with tag 0 to app "_ManagedAppProcess_Default"
*Jun 29 22:59:25.946: //1918/52D9DE6590DF/CCAPI/ccCallProceeding:
*Jun 29 22:59:25.946: //1918/52D9DE6590DF/CCAPI/ccCallDisconnect:
*Jun 29 22:59:25.946: //1918/52D9DE6590DF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 74.81.71.18;branch=z9hG4bK5664.7c9f9299d883437fed9b5d0d1ae56b70.0,SIP/2.0/UDP 67.231.5.110:5060;branch=z9hG4bK08Ba4c86daabafebcfd
Date: Mon, 29 Jun 2015 22:59:25 GMT
Content-Length: 0
*Jun 29 22:59:25.950: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 32
Content-Length: 332
Privacy: off
v=0
t=0 0
a=fmtp:18 annexb=no
a=fmtp:96 mode=30
a=fmtp:101 0-15
a=sendrecv
a=ptime:30
*Jun 29 22:59:25.950: //1918/52D9DE6590DF/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:+17702586200@74.81.71.18>;tag=15D8484-267E
Content-Length: 0
Sent:
Content-Length: 0
*Jun 29 22:59:26.662: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1072137542 ACK
Max-Forwards: 32
Content-Length: 0
*Jun 29 22:59:26.662: //1918/52D9DE6590DF/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x70910304, Tag=0x0, Call Id=1918,
*Jun 29 22:59:26.662: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jun 29 22:59:26.662: :cc_free_feature_vsa freeing 731C5918
*Jun 29 22:59:26.662: vsacount in free is 0
*Jun 29 22:59:26.686: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 32
Content-Length: 0
*Jun 29 22:59:26.690: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Record-Route: <sip:65.254.44.194;lr=on;ftag=gK082c6383;vsf=AAAAABkJCwEPCwcFAgJzA3cYBR0DHQAAAB8BMTA-;dlgcor=732.1d3>
Via: SIP/2.0/UDP 65.254.44.194;branch=z9hG4bK408a.cf297b9ef0cbd3a695d136423aaabbf7.0
Via: SIP/2.0/UDP 67.231.1.110:5060;branch=z9hG4bK08Becc1f2c6a5f7ddd5
From: "BURLINGTON ON " <sip:2899621735@67.231.1.110>;tag=gK082c6383
Call-ID: 940064013_128397301@67.231.1.110
CSeq: 938934862 INVITE
Max-Forwards: 32
Content-Length: 332
Privacy: off
v=0
o=Sonus_UAC 944877511 456657495 IN IP4 67.231.1.110
t=0 0
m=audio 26744 RTP/AVP 0 18 96 101
a=fmtp:18 annexb=no
a=fmtp:96 mode=30
a=fmtp:101 0-15
a=sendrecv
a=ptime:30
*Jun 29 22:59:26.694: //-1/534E72EB90E4/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=17702586200
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Jun 29 22:59:26.694: //-1/534E72EB90E4/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1919
*Jun 29 22:59:26.694: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jun 29 22:59:26.694: :cc_get_feature_vsa malloc success
*Jun 29 22:59:26.694: cc_get_feature_vsa count is 1
*Jun 29 22:59:26.694: :FEATURE_VSA attributes are: feature_name:0,feature_time:1931237664,feature_id:860
*Jun 29 22:59:26.694: //1919/534E72EB90E4/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*Jun 29 22:59:26.694: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 32
Content-Length: 332
Privacy: off
v=0
t=0 0
a=fmtp:18 annexb=no
a=fmtp:96 mode=30
a=fmtp:101 0-15
a=sendrecv
a=ptime:30
*Jun 29 22:59:26.698: //1919/534E72EB90E4/CCAPI/cc_process_call_setup_ind:
Event=0x6B6CF220
*Jun 29 22:59:26.698: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Jun 29 22:59:26.698: //1919/534E72EB90E4/CCAPI/ccCallSetContext:
Context=0xC1914CD0
>>>>CCAPI handed cid 1919 with tag 0 to app "_ManagedAppProcess_Default"
*Jun 29 22:59:26.698: //1919/534E72EB90E4/CCAPI/ccCallProceeding:
*Jun 29 22:59:26.698: //1919/534E72EB90E4/CCAPI/ccCallDisconnect:
*Jun 29 22:59:26.698: //1919/534E72EB90E4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 65.254.44.194;branch=z9hG4bK408a.cf297b9ef0cbd3a695d136423aaabbf7.0,SIP/2.0/UDP 67.231.1.110:5060;branch=z9hG4bK08Becc1f2c6a5f7ddd5
Date: Mon, 29 Jun 2015 22:59:26 GMT
Content-Length: 0
*Jun 29 22:59:26.702: //1919/534E72EB90E4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Content-Length: 0
Sent:
To: <sip:+17702586200@65.254.44.194>;tag=15D8770-1277
Content-Length: 0
*Jun 29 22:59:27.402: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 938934862 ACK
Max-Forwards: 32
Content-Length: 0
*Jun 29 22:59:27.402: //1919/534E72EB90E4/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x70910304, Tag=0x0, Call Id=1919,
*Jun 29 22:59:27.402: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jun 29 22:59:27.402: :cc_free_feature_vsa freeing 731C5918
*Jun 29 22:59:27.402: vsacount in free is 0
*Jun 29 22:59:27.438: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Record-Route: <sip:74.81.71.18;lr=on;ftag=gK0c7e10b1;vsf=AAAAABkJCwEPCwcFAgJzA3cYBR0DHQAAAB8BMTA-;dlgcor=06f.db42>
Via: SIP/2.0/UDP 74.81.71.18;branch=z9hG4bK53d7.1f2232694640234be56d96298e2b78d5.0
Via: SIP/2.0/UDP 67.231.1.110:5060;branch=z9hG4bK0cB6eeade8670c18e81
From: "BURLINGTON ON " <sip:2899621735@67.231.1.110>;tag=gK0c7e10b1
Call-ID: 940351616_125295536@67.231.1.110
CSeq: 1522313921 INVITE
Max-Forwards: 32
Content-Length: 334
Privacy: off
v=0
o=Sonus_UAC 1875817445 1069076280 IN IP4 67.231.1.110
t=0 0
m=audio 63042 RTP/AVP 0 18 96 101
a=fmtp:18 annexb=no
a=fmtp:96 mode=30
a=fmtp:101 0-15
a=sendrecv
a=ptime:30
*Jun 29 22:59:27.442: //-1/53C0963890E9/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=17702586200
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Jun 29 22:59:27.442: //-1/53C0963890E9/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1920
*Jun 29 22:59:27.442: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jun 29 22:59:27.442: :cc_get_feature_vsa malloc success
*Jun 29 22:59:27.442: cc_get_feature_vsa count is 1
*Jun 29 22:59:27.442: :FEATURE_VSA attributes are: feature_name:0,feature_time:1931237664,feature_id:861
*Jun 29 22:59:27.442: //1920/53C0963890E9/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*Jun 29 22:59:27.454: //1920/53C0963890E9/CCAPI/cc_process_call_setup_ind:
Event=0x6B6CF220
*Jun 29 22:59:27.454: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Jun 29 22:59:27.454: //1920/53C0963890E9/CCAPI/ccCallSetContext:
Context=0xC1913810
>>>>CCAPI handed cid 1920 with tag 0 to app "_ManagedAppProcess_Default"
*Jun 29 22:59:27.454: //1920/53C0963890E9/CCAPI/ccCallProceeding:
*Jun 29 22:59:27.458: //1920/53C0963890E9/CCAPI/ccCallDisconnect:
*Jun 29 22:59:27.458: //1920/53C0963890E9/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 74.81.71.18;branch=z9hG4bK53d7.1f2232694640234be56d96298e2b78d5.0,SIP/2.0/UDP 67.231.1.110:5060;branch=z9hG4bK0cB6eeade8670c18e81
Date: Mon, 29 Jun 2015 22:59:27 GMT
Content-Length: 0
Sent:
To: <sip:+17702586200@74.81.71.18>;tag=15D8A68-1F77
Content-Length: 0
*Jun 29 22:59:27.982: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1522313921 ACK
Max-Forwards: 32
Content-Length: 0
*Jun 29 22:59:27.982: //1920/53C0963890E9/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x70910304, Tag=0x0, Call Id=1920,
*Jun 29 22:59:27.982: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jun 29 22:59:27.982: :cc_free_feature_vsa freeing 731C5918
*Jun 29 22:59:27.982: vsacount in free is 0
06-29-2015 03:22 PM
By checking the logs, looks we have an issue TCP connection error to me. can you please check whats on the dial-peer its configured can you please try change session transport mode to UDP and check what is the si-ua status? Please also post me the show run from the Gateway.
Sent:
CSeq: 478 INVITE
Content-Length: 0
Received:
CSEQ: 478 ACK
MAX-FORWARDS: 70
CONTENT-LENGTH: 0
Br,
Nadeem Ahmed
