06-29-2015 11:02 PM - edited 02-21-2020 08:19 PM
If we use AnyConnect 3.1 with RSA SecureID, the token code is 6 characters. If the users PIN is 4 characters, then the total password for AnyConnect is 10 characters. If their PIN is 8, then the Cisco password becomes 14 characters. Can it be longer?
How many total characters are usable for the Anyconnect client authentication?
We are not going to require an extrermely long password, but we do not want to restrict the user from using a long password/passphrase if they wish. I need to know what the limitations are for Cisco AnyConnect before we set the maximum length on the RSA side.
Solved! Go to Solution.
06-30-2015 07:36 PM
ASA local user passwords are limited to 32 characters, and when using extended authentication (AAA server like in your case) it supports input of password length up to 128 characters
Abaji.
06-30-2015 07:36 PM
Abaji.
