Unity Connection uptime in PefrMon logs
matej.niznik
Hello Guys,
Is there possiblity to find out uptime of a server in Perfmon logs ? Unity Connection 7.1.5 crashed and I want to know what was the server uptime. Is it possible to trace it back ?
Thanks for feeback, Matej
Manish Gogna
I don't think its possible through perfom. However you can use the following command to get restart timing info
file view install system-history.log
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/116717-trouble-cucm-shutdown-00.html
Manish
- Do rate helpful posts -
Manish Gogna
Manish
Thank you.
It shows exactly what I was looking for.
Matej
