06-30-2015 10:57 AM - edited 03-11-2019 11:12 PM
Hello. Hoping someone could help with this issue.
It's been a while since I've had to access the firewall (probably the last time was when we had it installed and our vendor helped us with configuration) but for some reason I can't get to it anymore by IP address in the browser.
For Chrome, it's firing back that the connection was interrupted, while IE is complaining about turning on TLS (even though it's checked). Firefox says the connection has been reset.
We haven't updated or done anything to this guy in a while, so I'm not sure what may have happened in between then and now. I can access it just fine from telnet, just not via browser (so I could get ASDM installed). Pings to the IP address come back okay.
I'll paste in the particulars that I think are relevant and I'll try not to include unnecessary stuff. (if you're curious about the presence or lack of certain entries, just lmk and I'll check for them)
Hardware: ASA5525, 8192 MB RAM, CPU Lynnfield 2394 MHz, 1 CPU (4 cores)
ASA Version 9.2(1)
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 10.100.254.1 255.255.255.0
asdm image disk0:/asdm-721.bin
user-identity default-domain LOCAL
aaa authentication http console LOCAL
aaa authentication serial console LOCAL
aaa authentication ssh console LOCAL
aaa authentication telnet console LOCAL
aaa authentication enable console LOCAL
http server enable
http 10.0.0.0 255.0.0.0 inside
on show ssl:
Accept connections using SSLv2 or greater and negotiate to SSLv3 or TLSv1
Start connections using SSLv3 and negotiate to SSLv3 or greater
Enabled cipher order: rc4-sha1 dhe-aes128-sha1 dhe-aes256-sha1 aes128-sha1 aes256-sha1 3des-sha1
The usernames we use are defined and passworded with privilege 15
I noticed some other people have the http line marked as 'management' instead of 'inside'. is that just an older version or something?
Is there something I should look for in particular to address this?
Any help is appreciated. Thanks in advance!
Solved! Go to Solution.
06-30-2015 05:58 PM
Are you trying to access the "inside" interface on the CSM server itself ?
Rest of the configuration looks good.
Note:- Make sure you have the client connected behind the Inside interface for this to work.
Thanks and Regards,
Vibhor Amrodia
06-30-2015 05:58 PM
Thanks and Regards,
Vibhor Amrodia
07-01-2015 09:42 AM
Yes, I'm trying to get to it from my system which is on a 10.x.x.x address, navigating to the inside address (10.100.254.1), but it doesn't resolve to the usual page that prompts to download the ADSM installer. As I mentioned, I can telnet to that address just fine, so not sure where the disconnect is.
Interestingly, SSH access doesn't seem to work either. I see entries there that should cover it though:
Here's some other tidbits in reference to my observations above.
telnet 10.0.0.0 255.0.0.0 inside
telnet 172.16.0.0 255.255.255.0 inside
telnet timeout 5
ssh stricthostkeycheck
ssh <omitted> 255.255.254.0 outside
ssh <omitted> 255.255.255.192 outside
ssh 10.0.0.0 255.0.0.0 inside
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
management-access inside
(or are those entries for keys affecting the ssh side?)
here's show run http's output
http server enable
http <omitted> 255.255.255.192 outside
http <omitted> 255.255.254.0 outside
http <omitted> 255.255.255.255 outside
http 172.16.0.0 255.255.255.0 inside
In any case, what I'm trying to figure out is the http side of the problem, so not sure where else to look for that.
07-08-2015 09:46 AM
This was resolved. Looks like our web filtering was the culprit as we noticed we had access when we sent a reboot to the appliance. Fixed the IP range on that and now we're fine.
Since I couldn't mark my own post as an answer, I marked yours just to clear it.
Thanks for the replies.
