06-30-2015 11:14 AM - edited 03-05-2019 01:46 AM
I am using the following syntax but am unable to save my image to my tftp server:
Directory of flash:/
2 -rwx 2072 Apr 19 2011 03:29:42 +00:00 multiple-fs
606 -rwx 616 Apr 3 2011 03:21:01 +00:00 vlan.dat
607 -rwx 5 Apr 19 2011 03:29:42 +00:00 private-config.text
609 -rwx 2323 Apr 19 2011 03:29:42 +00:00 config.text
3 drwx 512 Mar 1 1993 00:17:37 +00:00 c2960c405-universalk9-mz.150-2.SE5
59996160 bytes total (40126976 bytes free)
C2960C#$-universalk9-mz.150-2.SE5/c2960c405-universalk9-mz.150-2.bin tftp:
Address or name of remote host []? 192.168.145.173
Destination filename [c2960c405-universalk9-mz.150-2.bin]?
%Error opening flash:/c2960c405-universalk9-mz.150-2.SE5/c2960c405-universalk9-mz.150-2.bin (No such file or directory)
C2960C#
Any help greatly appreciated.
Randall
Solved! Go to Solution.
06-30-2015 02:55 PM
Did you cd to the directory?
cd c2960c405-universalk9-mz.150-2.SE5
Then try the copy from there.
06-30-2015 02:55 PM
06-30-2015 03:02 PM
That did it. I cd to that directory and used the same syntax and it worked like a champ!
C2960C#$-universalk9-mz.150-2.SE5/c2960c405-universalk9-mz.150-2.SE5.bin tftp
Address or name of remote host []? 192.168.145.137
Destination filename [c2960c405-universalk9-mz.150-2.SE5.bin]?
15208832 bytes copied in 57.940 secs (262493 bytes/sec)
C2960C#
Many Thanks!!!
06-30-2015 03:22 PM
Uhhh ... Why not just go to the Cisco website and download the image?
