07-01-2015 05:14 AM
Hello everyone !
I'm posting on this forum because i'm having an issue with a stack of 3750X.
All power supply are OK when i check them, but when i do an snmpwalk, it return like one of the power supply is faulty :
ETA1-NR16001#sh env power all
SW PID Serial# Status Sys Pwr PoE Pwr Watts
1A C3KX-PWR-350WAC DTN1603L0H5 OK Good Good 350/0
1B C3KX-PWR-350WAC LIT16020TC2 OK Good Good 350/0
2A C3KX-PWR-350WAC LIT16210ANR OK Good Good 350/0
2B C3KX-PWR-350WAC LIT16020TJW OK Good Good 350/0
the snmpwalk :
OID=.1.3.6.1.4.1.9.9.13.1.4.1.2.1023, Type=OctetString, Value=Switch#1, Fan#1
OID=.1.3.6.1.4.1.9.9.13.1.4.1.2.1025, Type=OctetString, Value=Switch#1, Fan#2
OID=.1.3.6.1.4.1.9.9.13.1.4.1.2.2036, Type=OctetString, Value=Switch#2, Fan#1
OID=.1.3.6.1.4.1.9.9.13.1.4.1.2.2042, Type=OctetString, Value=Switch#2, Fan#2
OID=.1.3.6.1.4.1.9.9.13.1.4.1.3.1023, Type=Integer, Value=1
OID=.1.3.6.1.4.1.9.9.13.1.4.1.3.1025, Type=Integer, Value=1
OID=.1.3.6.1.4.1.9.9.13.1.4.1.3.2036, Type=Integer, Value=1
OID=.1.3.6.1.4.1.9.9.13.1.4.1.3.2042, Type=Integer, Value=1
OID=.1.3.6.1.4.1.9.9.13.1.5.1.2.1022, Type=OctetString, Value=Sw1, PS1 Normal, RPS NotExist
OID=.1.3.6.1.4.1.9.9.13.1.5.1.2.1024, Type=OctetString, Value=Sw1, PS2 Normal, RPS NotExist
OID=.1.3.6.1.4.1.9.9.13.1.5.1.2.2034, Type=OctetString, Value=Sw2, PS1 Normal, RPS NotExist
OID=.1.3.6.1.4.1.9.9.13.1.5.1.2.2035, Type=OctetString, Value=Sw2, PS2 Faulty, RPS NotExist
I'm actually running an IOS wich is OK if i look at this bug report :
https://tools.cisco.com/bugsearch/bug/CSCtx16194/?reffering_site=dumpcr
sh ver :
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(58)SE2, RELEASE SOFTWARE (fc1)
I dont know how to fix it.
Thanks for your help !
07-01-2015 09:28 AM
Hi ,
you have done your homework very well.. thanks for that ,however the code you are running is still impacted by the BUG::
CSCtx16194 is fixed in the following 43 versions
12.2(55.6.93)SE8
15.0(2.0.43)EB
15.0(2.1)EJ
15.0(2.1.5)SE3
15.0(2.70.1)SE3
15.1(1.7.1)EC
15.2(1)EX0.116
15.2(1)EX0.54
15.2(1.0.96)IPI2
15.2(1.1.13)EY
15.2(1.1.21)E
15.2(1.1.5)EY
15.2(2.0)MCP29
15.2(2.0.0)L53
15.2(2.0.0)QSD
15.2(2.0.10)QSD
15.2(2.0.15)PI-PD
15.2(2.0.41)PI3
15.2(2.0.44)EA
15.2(2.0.66)PI_PD
15.2(2.0.72)PI3
15.2(2.0.9)MW
15.2(2.1.1)E
15.2(2.1.13)PI3
15.2(2.1.26)CD
15.2(2.1.40)CD
15.2(2.1.5)E
15.2(2.1.7)CD
15.2(2.10.1)SDN
15.2(2.10.30)SDN
15.2(2.10.38)SFW
15.2(2.10.66)SDN
15.2(2.2.0)E
15.2(2.50.89)SDN
15.2(3.0.16)PID
15.2(3.0.18)CC4
15.2(3.0.27)PI4
15.2(3.0.30)MG
15.2(3.0.5)MG
15.2(3.0.7)WC
15.2(4.0.1)DL
15.2(4.0.42)PI5
Thanks-
Afroz
***Ratings Encourages Contributors ****
