07-01-2015 07:46 AM - edited 07-05-2021 03:29 AM
I have Cisco 2500 (2504) & 5500 (5508) series wireless controllers running with the IOS version '7.2.111.3' , want to understand whether this series is still vulnerable with SSLv3 or do we need have any remediation plans?
Will appreciate your quick reply.
Sajin P
Solved! Go to Solution.
07-03-2015 07:50 AM
07-01-2015 01:37 PM
yes , wlcs are impacted by this Vul ,
please see this bug which opened in this regards :
https://tools.cisco.com/bugsearch/bug/CSCur27551
u will find all the info you will need,
but please note that the SSLv3 is no secured ,and it's vulnerability affect all products (cisco/non-cisco) , so disable it where ever u see it , on cisco and non-cisco , on servers and clients.
http://www.cisco.com/c/en/us/support/docs/security/email-security-appliance/118620-technote-esa-00.html
i hope that answer your question
07-03-2015 03:48 AM
Thanks for your reply Ali,
I am running 7.2.111.3 in my WLC, However my WLC is not accepting following commands "fipsconfig & sslconfig" to check current running SSL version.
Is there any commands to identify the running SSL versions? My GUI is running with SSLV3 I would need to change that as well to TLS V1.
Sajin P | +91-9916709992
07-03-2015 07:50 AM
show network summary will show you the SSL versions enabled ,
07-05-2015 12:56 PM
Thanks Ali, I can see I am running with SSL V2 on all the WLC devices. So, is that version also impacted with vulnerability & we would need to move to TLS V1 ?
RF-Network Name............................. admin-1
Web Mode.................................... Disable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Enable
OCSP........................................ Disabled
OCSP responder URL..........................
Secure Shell (ssh).......................... Enable
