Cannot access outside from guestwifi (dmz)
Chad Campbell
Guys,
I am trying to create a guestwifi, but it does not seem to work, i will post my configurations below. Please let me know any additional information.
ASA Version 8.2(1)
interface GigabitEthernet0/3
 nameif guestwifi
 security-level 5
 ip address 192.168.175.1 255.255.255.0
global (guestwifi) 1 interface
dhcpd dns 8.8.8.8 8.8.4.4
dhcpd lease 86400
dhcpd option 3 ip 192.168.175.1
dhcpd address 192.168.175.10-192.168.175.253 guestwifi
dhcpd enable guestwifi
MonogramASA# packet-tracer input guestwifi icmp 192.168.175.12 0 0 216.58.216.110
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   0.0.0.0         0.0.0.0         outside
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 6
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 10836954, packet dispatched to next module
Result:
input-interface: guestwifi
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: allow
Do you have something like global (outside) 1 interface? If so, then the NAT statement would be
nat(guestwifi)1 192.168.175.0 255.255.255.0
i don't this you need global (guestwifi) 1 interface
John
**Please rate posts you find helpful**
9 Replies 9
johnd2310
Level 8
Level 8
HI,
Need more infor on your configuration. is the wireless access point configuration okay? Do you have a NAT device between Internet and firewall and is it configure okay?
John
Thanks John, The devices connects to the AP and gets a DHCP address successfully from the ASA, but are not able to access the internet through the outside interface. What do you mean do I have a NAT device?
Is the firewall connected to the Internet or do you have another device between the firewall and the Internet?
thanks
John
The firewall is directly connected to the internet.
IS this correct global (guestwifi) 1 interface? Where is the NAT  config for the 192.168.175.0/24 network?
John
John,
I did not include 1, I thought the global nat statement would have covered the NAT (i guess not), but I do no have a NAT config for that network, can you give me a simple command to show me what it should look like?
John
Thanks John, I did see that and I just entered the command you recommended, I will have my team to test, while I wait I am going to find some videos about natting.
I will let you know, thanks again.
Chad Campbell
Thanks John this work!
