07-03-2015 07:06 AM - edited 03-18-2019 04:41 AM
Dear all
If I'm creating the Conductor Template und TMS Provisioning for the Personal Meeting Room, I have the Possibility the create the Numeric Alias pattern from, this pattern can be generate or also from the Active Directory {office Phone}
but the Problem which I have is that my phone number in the Active direcory is stored with space, I can red the
example my Office Phone is: 123 45 67
my Regex to insert the last 4digit with a prefix:
\d{1}\s?\d{1}\s?\d{1}\s?\d{1}$
880145 67
After I have Setup the CMR room I have the right Number but also with the space.
Any Idea How can I remove the space?
Because the Problem is the Numeric Alias is also on the Conductor in the same form created.
Aatched some screenshot.
Any Input very appreciated.
best Regards
Georg
Solved! Go to Solution.
07-03-2015 10:35 AM
I'm not able to test it in using TMSPE because our telephone entries have a hypen "-", but try the following regex.
(\d{2}) (\d{2})$
07-03-2015 10:35 AM
(\d{2}) (\d{2})$
07-08-2015 07:25 AM
Hi Patrick
great!
thank you it works.
Best regards
Georg
