07-05-2015 09:43 AM - edited 03-19-2019 09:46 AM
I will be migrating/upgrading a legacy cucm version 4.2 to 10.5 on BE6K server. i have planned to do the following steps but i need to clear out some confusions:-
1. install DMA on the MCS publisher and take the backup of the current CUCM (4.2) and then copy it to external har drive.
2. insert the cucm 7.1.5 media in the current mcs server and install 7.1.5 on it and then restore the tar file as taken out from DMA.
3. Install PCD on the BE6K server and then make cucm virtual machines(migration destination) without powering on. I HAVE A CONFUSION THAT DO I NEED TO HAVE A SEPARATE SWITCH FOR THIS PROCESS OR I CAN USE THE SAME PRODUCTION NETWORK SWITCH???
4. After configuring PCD, discover the existing cluster and then create a migration task in it with source and destination clusters. I HAVE CONFUSION THAT HOW WILL IT DISCOVER THE EXISTING 7.1.5 CLUSTER IF I USE A SEPARATE SWITCH (BLACK HOLE AS I HAVE READ SO MANY THREADS HERE) FOR MY NEW UCS BOX..??
5.THEN migrate publisher and subcriber one by one.
Broadly i have planned for these steps with the migration of licensing as well but please i need some input on the use of PCD as iwill be using it for the first time. I just need to understand that how can i assign the same IP ADDRESS to my newly created VMs as of the older CUCM 7.1.5 cluster..??
Also i need some input on the new installation of the cucm 7.1.5 media in the mcs server..the downtime is must there.?? I have verified the MCS version as it will support the cucm 7.1.5 as an intermediate release of my M1 migration.
thanks in advance
Anshuman Singh
+971 555012936
Solved! Go to Solution.
07-07-2015 02:28 AM
Hi Anshuman,
if u need to use same MCS server for 7.1.5 on which Call manager 4.x is installed, u need to check whether MCS H/W supports 7.x.You can keep the same IP address for new ones[take maintenance window]
Please check the steps for PCD
Sequence of steps:
regds,
aman
07-05-2015 10:40 PM
Hi Anshuman,
You can change the IP addresses of new servers through PCD.
Since u need to use the same MCS server for DMA [which needs to be installed on Publisher] , it would require a reboot.
After this ,you can install CUCM 7.1.5 on UCS platform[non-production],restore.
Now , u can put this in production and migrate to CUCM 10.X through PCD. Here, u can change the IP addresses of destination cluster.
If u are using static IP addresses for IP phones, then, u would have to change the IP addresses back to original ones else u can change in DHCP pool for new ones tftp.
regds,
aman
07-05-2015 11:30 PM
Hi Aman,
Thank you for your reply..
i dont want to change the ip address of my cucm cluster and thats y i have decided to install the CUCM 7.1.5 on the same mcs servers(please correct me if i am wrong).
actually my question is about the cluster discovery of PCD that when i will Deploy the Cisco-recommended OVA for Unified Communications Manager Release 10.5(1) to create the blank VMs for the destination cluster node installation an after that i will Create the appropriate number of target virtual machines on the ESXi hosts (one new virtual machine for each Cisco Unified Communications Manager server in the existing cluster) by using the Cisco OVA(s) , therefore here i will have to configure the network settings for the newly created VMs. so my confusion is here that how can i assign it the same IP address of my MCS 7.1.5 version pub-sub..???
And also please clear my confusion about adding the ESXi host in my PCD inventory..
thanks.
Anshuman Singh
07-07-2015 02:28 AM
Hi Anshuman,
Sequence of steps:
regds,
aman
