C60 Phonebook Results - Folder Entry Syntax
twingate111
All,
I just need a copy of the results of a C60 TC 7.3x phone book search that show what syntax is returned for a folder entry so I can parse the folder IDs and names.  Obviously, I don't have a C60 handy to test with.  Your help will be appreciated!
Tom
Hi Tom,
Yeah, I don't have any systems that use folders or ones I can easily manipulate to create them.
You can also take a look at the DevNet site which provides information on the API's.
https://developer.cisco.com/site/tp-av-integrator/howtos/phonebook.gsp
Sorry I couldn't help more.
6 Replies 6
xcommand phonebook search PhoneBookType: Corporate ContactType: Contact SearchString: "" Recursive: False
Hi Nicholas,
Thanks for responding to my question although I think your answer was the API command to search the phone book, not the results of a search. I'm trying to figure out how to parse the folder IDs and names out of the response to a search.
Tom
Data Scrub from that command.
OK
*r ResultSet ResultInfo Offset: 0
*r ResultSet ResultInfo Limit: 50
*r ResultSet ResultInfo TotalRows: 29
*r ResultSet Contact 1 Name: “Test Room 1"
*r ResultSet Contact 1 ContactId: "e_36"
*r ResultSet Contact 1 ContactMethod 1 ContactMethodId: "1"
*r ResultSet Contact 1 ContactMethod 1 Number: "H323:10.10.1.15"
*r ResultSet Contact 1 ContactMethod 1 Protocol: H323
*r ResultSet Contact 1 ContactMethod 1 CallRate: 1152
*r ResultSet Contact 1 ContactMethod 2 ContactMethodId: "2"
*r ResultSet Contact 1 ContactMethod 2 Number: "SIP:5551000@example.com"
*r ResultSet Contact 1 ContactMethod 2 Protocol: SIP
*r ResultSet Contact 1 ContactMethod 2 CallRate: 1152
*r ResultSet Contact 2 Name: “Test Room 2“
*r ResultSet Contact 2 ContactId: "e_122"
*r ResultSet Contact 2 ContactMethod 1 ContactMethodId: "1"
*r ResultSet Contact 2 ContactMethod 1 Number: "H323:10.10.4.15"
*r ResultSet Contact 2 ContactMethod 1 Protocol: H323
*r ResultSet Contact 2 ContactMethod 1 CallRate: 1152
*r ResultSet Contact 2 ContactMethod 2 ContactMethodId: "2"
*r ResultSet Contact 2 ContactMethod 2 Number: "SIP:5551001@example.com”
*r ResultSet Contact 2 ContactMethod 2 Protocol: SIP
*r ResultSet Contact 2 ContactMethod 2 CallRate: 1152
*r ResultSet Contact 3 Name: “Test Room 3“
*r ResultSet Contact 3 ContactId: "e_156988"
*r ResultSet Contact 3 ContactMethod 1 ContactMethodId: "1"
*r ResultSet Contact 3 ContactMethod 1 Number: "H323:10.10.12.2"
*r ResultSet Contact 3 ContactMethod 1 Protocol: H323
*r ResultSet Contact 3 ContactMethod 1 CallRate: 1152
*r ResultSet Contact 4 Name: “Test Room 4“
*r ResultSet Contact 4 ContactId: "e_149699"
*r ResultSet Contact 4 ContactMethod 1 ContactMethodId: "1"
*r ResultSet Contact 4 ContactMethod 1 Number: "H323:10.10.1.213"
*r ResultSet Contact 4 ContactMethod 1 Protocol: H323
*r ResultSet Contact 4 ContactMethod 1 CallRate: 1152
*r ResultSet Contact 4 ContactMethod 2 ContactMethodId: "2"
*r ResultSet Contact 4 ContactMethod 2 Number: "SIP:5551002@example.com”
*r ResultSet Contact 4 ContactMethod 2 Protocol: SIP
*r ResultSet Contact 4 ContactMethod 2 CallRate: 1152
Hi again,
Thanks for the fast response!  I really appreciate you trying to help.  It appears your CODEC doesn't have any folders created.  I'm pretty sure the response contains the word "Folder" when the record represents a folder.
Tom
Hi Tom,
Hi Nicholas,
That link had an example with folders!!  It was just what I needed.  So, again, thanks for your time and help!  Hope you have a great day.
Best regards,
Tom
