Catalyst 2960X mls qos srr-queue input no longer a valid command?
jgwilson21
I am trying to configure Catalyst 2960X switch with QoS and I want to use the command: "mls qos srr-queue input cos-map queue" and every time I get an error saying that is not a command.. The input keyword does not seem to be a command anymore while output still does work. Thanks in advance for the help
Vinit Jain
I dont think this command is supported as per CCO: This command is not present in the command reference.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/qos/command_reference/b_qos_152ex_2960-x_cr/b_qos_152ex_2960-x_cr_chapter_011.html#wp4083474629
Even i checked in my lab (2960X running 15.2(2)E release and it doesn't show this command:
F340.04.17-2900-1#sh ver | in image
System image file is "flash:c2960x-universalk9-mz.152-2.E.bin"
F340.04.17-2900-1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
F340.04.17-2900-1(config)#mls qos srr
F340.04.17-2900-1(config)#mls qos srr-queue ?
  output  output keyword
Hope this helps.
Vinit
--Vinit
Hi Vinit,
I have the same problem.. we are currently replacing our old 3750G with 2960XR.. this command is available on the old switch and I am trying to configure the new switch with the same config.
Old Switch:
WS-C3750G-48PS-E
System image file is "flash:/c3750e-universalk9-mz.122-55.SE5.bin"
New Switch:
WS-C2960XR-48LPS-I
System image file is "flash:/c2960x-universalk9-mz.152-2.E7/c2960x-universalk9-mz.152-2.E7.bin"
Thanks!
JV
