ā07-07-2015 02:42 AM - edited ā03-08-2019 12:51 AM
We have had a layer 2 national Ethernet link installed between 2 of our sites with a circuit presented to us at each site by the ISP. We will be trunking 3 or 4 vlans over it. I am just thinking about the port configs on each end on the switches. Should the layer 2 link be treated as any layer two link configured as a trunk on the switchports at each end with specific vlans allowed or is there any special config required I don't know about.
Solved! Go to Solution.
ā07-07-2015 05:40 AM
It should be the same as any other physical link you have. So, you can add as many vlans you need or just trunk the ports on each side.
ā07-07-2015 09:58 AM
Create the trunk port but also include the command 'switchport trunk allowed vlan ##'
ā07-07-2015 12:46 PM
Thanks guys, thought that was the case but just wanted to verify, thankyou
