07-07-2015 10:04 AM - edited 03-17-2019 03:34 AM
Can somebody help me with this?
I´ve configured an image into an ip phone, but my client don´t want to change the image step by step.
I´d like to know how I can change the image since my computer to all the ip phones without configuring by hand
Solved! Go to Solution.
07-07-2015 01:26 PM
07-07-2015 01:32 PM
This has been asked, literally, hundreds of times at CSC, a simple search would have provided the answer.
PLEASE, search for answers before posting.
I also cover the topic in my FAQ
http://docwiki.cisco.com/wiki/Endpoints_FAQ
07-07-2015 10:07 AM
I am not sure I understand the issue exactly, could you please elaborate it little more?
07-07-2015 10:21 AM
sure
Like I said
I´d like to know if there´s a procedure to configure an image and when all of my phones turn on that image appears by default without configuring by hand
For exampe I have a new phone and when I turn it on I´d like that image appears in the display automatically.
I´m using Call Manger version 10.5.1
07-07-2015 11:21 AM
You will need to upload the full image a d thumbnail image on cucm servers in correct format and folder as per the ip phone customization guide. Once it is pushed to the phones the users need to manually select the image at least once to apply it. You may get a customized solution for your requirement through a third party though.
07-07-2015 01:26 PM
You will need a third-party tool to automate this.
07-07-2015 01:32 PM
