The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally. New Here? Click here to learn more and get started.
Cisco Community is an active and collaborative place to learn more about our products and ask questions of peers and Cisco experts! Check out some of the most popular conversations happening right now!
헗헲헹혁헮 헔헶헿헹헶헻헲's phone number to call and talk with a live 헿헲헽헿헲혀헲헻혁헮혁헶혃헲 fast is ퟭ-ퟖퟖퟖ ✈ ퟖퟐퟗ ✈ 1316 // ퟭ-ퟖퟖퟖ ✈ ퟖퟐퟗ ✈ 1316 . Select your connection language upon call and choose the IVR option that best suits your query by looking through the ones ...
핃핦핗핥학핒핟핤핒's 24-hour rule refers to their policy that allows passengers to cancel or change their booking without a penalty if they do so within 24 hours of purchasing their ticket by dialing l +1-ퟴퟱퟱ-ퟱퟮퟲ-ퟬퟯퟬퟳor +1-ퟴퟱퟱ-ퟱퟮퟲ-ퟬퟯퟬퟳ ✈퐿ufthansa adheres to t...
Our Forum Alert III Secondary Crash Net (SCN) is inoperable. I've heard the cisco cm could be configured to set up some devices to act as a ringdown, they called it a “Switch Box.” This would allow our Base Operations guys to have a work around from ...
Wanted to understand the best practices when updating the prefix-list & data prefix list in SD-WAN network.For example I have the below prefix-listlist_abc: 10.10.10.0/24This prefix list has been used in Centralized policy.I wanted to added new subne...
Good day;Need help with how I can configure NAT overload with an existing vrf on a CAT9K_IOSXE V16.12. This is what I am struggling with, I currently have a vrf called AWSDX-S3. Now what I am trying to do is I have added a L2 SW and ran trunk ports...
I accidentally bricked my Cisco C9300L switch and no longer has IOS or Bootstrap. Can I save copy of IOS and Bootstrap from my other Cisco C9300L switch and save to USB drive? Then copy images onto the switch that is inoperable?
Bonjour a toutes et tous,je voudrais savoir comment se connecter via un PC sur l'interface d'administration d'un point d'accès CBX150AX.Merci d'avance pour vos reponsesJJ
Ask Me Anything Event Welcome to the Cisco Community Ask Me Anything conversation. Submit your questions from Wednesday, April 10, 2024 through Wednesday, April 24, 2024. Our Community VIPs, Kathy New and Maren Mahoney will be waiting to assist you ...
Hi Team,Our Router having many ikev2 proposal, as per TAC suggestion we need to combine in to single policy. Please let me know for this activity any down time needed ?
Hello, in VSOM, I have added a new Axis camera and created a new camera in the system and selected to replace the existing camera. It is working and recording but getting this error that will not clear: "Motion window is not configured on the camera....
We have wireless and wired devices that uses Bonjour (mDNS) service to discover each other. I need to configure both wired and wireless devices in the same VLAN . We have Cisco WLC 5520 and APs that support flexconnect feature. I need to configure AP...
A simple question....If I just knew where to find the answer:Doing MAC authentication on an 5520 WLC, I can see the MAC addresses accepted by the WLC if I issue the command:"sho macfilter summary"Can anyone tell me the equivalent command on a 9800 (y...
I configured NAT and DHCP relay in GNS3, and all hosts have end-to-end reachability, I can ping PC44 from PC11 and PC22, and also from PC33 if I configure a static IP address.On the NAT router (R11), I also configured DHCP relay with 'helper-address'...
