errors in the discover the server UCS B440 M2
CSCO11814843
I have the following errors in the discover the server UCS B440 M2 in the chasis UCS 5180 the firmware is 2.1(1f)
FSM
FSM Status: In Progress
Description:
Current FSM Name: Discover
Completed at:
Progress Status: 9%
Remote Invocation Result: End Point Protocol Error
Remote Invocation Error Code:1002
Remote Invocation Description: Unable to change blade power state-MC Error (-20): Management controller cannot or failed in progressing request
Thanks for you help
5 Replies 5
Keny Perez
Level 8
Level 8
Likely to be a power-on issue  "Unable to change blade power state"... open a TAC case to confirm and replace if needed.
-Kenny
jchavesd
Try to decommission and re-acknowledge the Blade. If the issue re-occurs a TAC case will need to be opened to replace Mobo
Jaiveer
This type error always come when we configure the server and we do not found any solution.
Alfredo Juarez
ANY SOLUTION???
Hi @Alfredo Juarez
This thread is 8 years old.  If you have a similar problem, it may be worth while starting a new thread. If your problem is related tot he original error mentioned "Remote Invocation Error Code:1002" then open a TAC case.
RedNectar aka Chris Welsh.
