07-24-2015 02:23 AM - edited 03-08-2019 01:05 AM
As far as I know, in a Dual Nexus 5k environment, w/c are configured for vPC. EvPC is available for FEX to be dual homed, one connection type to each of the Nexus switches. Such as the image below.
BUT, but but but, as the documentation goes, Nexus 7k models still do NOT support this kind of feature i.e., we cannot dual home a FEX such as a nexus 2k to two Nexus 7k in vPC, in w/c these NX7k switches are in vPC
Sooo the question is, its been a while, does it support it now?
As far as my research goes, n7k still does not support it.
On my research I actually encountered a post from 3 mos. ago, w/c says "no" to my question T.T
LINK: CLICK ME
Any inputs guys? :D
Solved! Go to Solution.
07-24-2015 10:34 AM
You are right, but Aru said the right thing. It supports dual homing as you show in the diagram, but not an enhanced vpc.
To be more clear here is an explanation of enhanced vpc -- Thanks to steve-fuller on another post.
"Enhanced vPC is a method that allows the connection of FEX in an active-active manner using vPC between the FEX and upstream Nexus switch, and at the same time connection of a device to the FEX host interfaces with a vPC."
Please refer below for more details.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/operations/interfaces/602_n1_1/N5K_Interfaces_Ops_Guide/n5k_enhanced_vpc.html#10241
Hope this makes it clear.
Madhu
**** Please rate useful posts ****
07-24-2015 04:55 AM
Nexus 7000 supports dual homed FEX but not enhanced vPC even on NX-OS 7.X , I am not seeing any road map to include this feature presently.
Aru
07-24-2015 07:42 AM
Hey Aru,
THis is probably epic but Cisco just released the latest release w/c was just released last month does support it :D
Version 7.2(0)D1(1) does support it
LINK: Configuring FEX
Qoute: Beginning with Cisco NX-OS Release 7.2(0)D1(1) , a Fabric Extender can support connections to two Cisco Nexus 7000 Series switches in active-active mode using a vPC
But yeah, probably still on the early stage. Hopefully we dont hit major bugs
07-24-2015 10:34 AM
Madhu
07-24-2015 10:36 AM
In earlier releases with N7K It was not possible even to do dual-homing fex with VPC.
With newer one it is introduced. But not to be confused with eVPC.
Madhu
07-25-2015 03:21 AM
07-24-2015 07:45 AM
Image proof! Taken from the document link
