07-25-2015 09:19 PM - edited 03-08-2019 01:06 AM
Placed a formatted (under DOS FAT32) 256 MB Cisco compact flash card in router
on SIMM section
This doesn't appear in the sh file system command or the sh version command
Place a 32 MB compact flash in same SIMM section on MOBO and router reads this via above commands
Unless the 256 MB isnt any good which is weird as I had just transferred the IOS to this.
Thanks again..:)
PS. Please advise if this is the correct area to post.
07-25-2015 10:10 PM
This is Video Over IP, please move to a relevant area, probably a general routing/ISR area
07-26-2015 12:06 AM
Thanks Mr Valencia for the hint
07-29-2015 12:46 AM
Sometimes the bootrom limits the size of supported flash on the router. Go to the download section of your device and see if there is a newer bootrom available.
07-29-2015 04:35 AM
Hi Karsten,
Thanks for the response. As I have found out. Apparently the bootrom is included with the current image I have. I can't understand how Cisco would limit this 2691 MPS router to just a 32 MB compact flash card limit considering the size of the IOS's are above 70mb.
I don't suppose you have other options?
07-29-2015 04:55 AM
If I remember right, these devices support at least 64 MB of flash. And with 12.4 as the last supported versions, the IOS shouldn't be larger then that.
All in all, when the 2600 routers were introduced (that was last century, wasn't it? ;-) ) 32 MB was not really much, but quite common.
But you are right, these limits are hard to understand. My HO-router is a 866VA. Before loading a new image, I have to delete the old one because the flash is to small for two images ... :-(
07-29-2015 05:33 AM
I'll have to check this (IOS sizes) and get back to you if I can Karsten.
07-30-2015 03:41 AM
Hi Karsten,
Cisco 2691 routers support up to 128 MB for compact flash
http://www.cisco.com/c/en/us/products/collateral/routers/3700-series-multiservice-access-routers/product_data_sheet09186a008009203f.html
So now have to purchase this flash. Thanks again
