07-26-2015 03:54 AM
I have successfully configured the Psuedowire between ASR9k and 7600 but end to end connectivity is not working. Here is my topology.
CE1 --------7600--------- ASR9k----------Nexus7k-------Nexus5k--------CE2
I can see psuedowire is up between 7600 and ASR9k.
7600#sh mpls l2transport vc
Local intf Local circuit Dest address VC ID Status
Gi1/8 Ethernet 2.2.2.2 1067 UP
7600#
Solved! Go to Solution.
08-02-2015 08:23 AM
Please, show Bundle-Ether1.75 from ASR9k. I think that you missed
rewrite ingress tag pop 1 symmetric
07-26-2015 07:44 AM
Hello
Are you able to perform pseudowire ping from 7600 to ASR9k. Also, Could you please share the below logs from both 7600 and ASR9k:
7600: - show version - show module - show run - show mpls l2 vc 1067 det ASR9k: - show version brief - show platform - show run - show l2vpn xconnect nei <nei> detail
Are you learning the mac-addresses from the CE's on both sides on each 7600 and ASR9k.
Can you configure an SVI on N7k (just to reduce the number of hops) and ping from CE1 to CE2(N7k).
Vinit
07-27-2015 05:03 AM
Here are the details
7600: - show version Version 12.2(33)SRD4 - show mpls l2 vc 1067 det
7600#sh mpls l2transport vc 75 detail
Local interface: Gi1/15 up, line protocol up, Ethernet up
Destination address: 4.4.4.4, VC ID: 75, VC status: up
Output interface: Te3/1, imposed label stack {16074 16000}
Preferred path: not configured
Default path: active
Next hop: 171.74.140.10
Create time: 4d18h, last status change time: 1d04h
Signaling protocol: LDP, peer 198.160.90.1:0 up
Targeted Hello: 2.2.2.2(LDP Id) -> 198.160.90.1
Status TLV support (local/remote) : enabled/supported
Label/status state machine : established, LruRru
Last local dataplane status rcvd: no fault
Last local SSS circuit status rcvd: no fault
Last local SSS circuit status sent: no fault
Last local LDP TLV status sent: no fault
Last remote LDP TLV status rcvd: no fault
MPLS VC labels: local 1092, remote 16000
Group ID: local 0, remote 167772448
MTU: local 9142, remote 9142
Remote interface description: Bundle-Ether1.75
Sequencing: receive disabled, send disabled
VC statistics:
packet totals: receive 197705, send 14564
byte totals: receive 14234716, send 3028095
packet drops: receive 0, seq error 0, send 0
7600#
ASR9k#
Group Test, state is up; Interworking none
AC: Bundle-Ether1.75, state is up
Type VLAN; Num Ranges: 1
VLAN ranges: [75, 75]
MTU 9142; XC ID 0xa0000006; interworking none
Statistics:
packets: received 51020, sent 1697
bytes: received 3469360, sent 797590
drops: illegal VLAN 0, illegal length 0
PW: neighbor 2.2.2.2, PW ID 75, state is up ( established )
PW class ipiw-e, XC ID 0xc0000004
Encapsulation MPLS, protocol LDP
Source address 4.4.4.4
PW type Ethernet, control word disabled, interworking none
PW backup disable delay 0 sec
Sequencing not set
PW Status TLV in use
MPLS Local Remote
Label 16000 1092
Group ID 0xa000120 unknown
Interface Bundle-Ether1.75 To/393283/ns01/Norcross/ISP/G0/23
MTU 9142 9142
Control word disabled disabled
PW type Ethernet Ethernet
VCCV CV type 0x2 0x2
(LSP ping verification) (LSP ping verification)
VCCV CC type 0x6 0x2
(router alert label) (router alert label)
(TTL expiry)
Incoming Status (PW Status TLV):
Status code: 0x0 (Up) in Notification message
Outgoing Status (PW Status TLV):
MIB cpwVcIndex: 3221225476
Create time: 26/07/2015 06:00:20 (1d05h ago)
Last time status changed: 26/07/2015 07:12:07 (1d04h ago)
Statistics:
packets: received 1697, sent 51020
bytes: received 797590, sent 3469360
ASR9k#
Cisco IOS XR Software, Version 4.3.4[Default]
07-27-2015 05:07 AM
I didnt see any mac addresses from the CEs
08-02-2015 08:23 AM
08-07-2015 12:39 AM
Hi Evgeniy,
It works.. Thanks for u r help..
