07-27-2015 02:23 PM - edited 03-08-2019 01:08 AM
yesterday I needed to update the firmware in 2 3750X-24T so they are the same as the rest of our 3750X's we have.
The first went as it should have however the second failed after I issued the "reload" command.
When rebooting this 3750X gets as far as
Front-end Microcode IMG MGR: Preparing to program device microcode...
Front-end Microcode IMG MGR: Preparing to program device[0]...594412 bytes.
Front-end Microcode IMG MGR: Programming device 0...rrrrrrwsssssssssssssssssssps
sssssssssssssssssspssssssssssssssssssspssssssssssssssssssspsssssssssssssssssssps
Then repeats "ssssssssssssssssssp"
Ware to from hear?
I have tried to reload the bin image into the firmware file into flash from a USB memeory stick but with no luck.
I am not sure if it is related but
After issuing the "flash_init" command, the 3750x seems to hang for a long time at
switch: flash_init
Initializing Flash...
mifs[2]: 10 files, 1 directories
mifs[2]: Total bytes : 2097152
mifs[2]: Bytes used : 612352
mifs[2]: Bytes available : 1484800
mifs[2]: mifs fsck took 2 seconds.
mifs[3]: 0 files, 1 directories
mifs[3]: Total bytes : 4194304
mifs[3]: Bytes used : 1024
mifs[3]: Bytes available : 4193280
mifs[3]: mifs fsck took 3 seconds.
mifs[4]: 5 files, 1 directories
mifs[4]: Total bytes : 524288
mifs[4]: Bytes used : 9216
mifs[4]: Bytes available : 515072
mifs[4]: mifs fsck took 1 seconds.
mifs[5]: 5 files, 1 directories
mifs[5]: Total bytes : 524288
mifs[5]: Bytes used : 9216
mifs[5]: Bytes available : 515072
mifs[5]: mifs fsck took 0 seconds.
-- MORE --
eventually it will come back to the "switch" prompt after a few "enter' keystrokes
any help would be appreciated.
John
07-27-2015 02:49 PM
Hi John, in my experience the "sssssssssssspssssssssssssssp" is all part of the ROM upgrade process. When you're in ROMMON mode (the "switch" prompt), try booting off your USB by using the following command:
