Cisco ASA - %ASA-4-402120: IPSEC: Received an ESP packet
MoeBasheer
I'm seeing VPN authentication failure  between local firewall going too two remote firewalls. We have other VPN connections existing on the local firewall to other remote firewalls but i'm not see authenication failed for their IPs.
Jul 28 2015 09:18:07: %ASA-4-402120: IPSEC: Received an ESP packet (SPI= 0xB7D49FAC, sequence number= 0xFC6D) from vpn_peer1 (user= 172.30.6.132) to 172.30.6.12 that failed authentication.
Jul 28 2015 09:18:07: %ASA-4-402120: IPSEC: Received an ESP packet (SPI= 0x4E380674, sequence number= 0x1117CD) from 1vpn_peer1  (user= XX.XX.XX.20) to 172.30.6.12 that failed authentication.
I have checked the VPN access list and they match on both side. I'm are currently running 8.3(2).
We cleared the tunnel but that didn't help.
Has anyone come across this before and found a solution.
Mohammed
crypto map np-cmap-outside 6 match address noc-vpn-acl
crypto map np-cmap-outside 6 set peer vpn_peer1
crypto map np-cmap-outside 6 set transform-set np-trans1-vc6-tunnel1-IzXR
crypto map np-cmap-outside 6 set security-association lifetime seconds 28800
crypto map np-cmap-outside 6 set security-association lifetime kilobytes 4608000
crypto map np-cmap-outside 8 match address hawaii-vpn-acl
crypto map np-cmap-outside 8 set peer vpn_peer2
crypto map np-cmap-outside 8 set transform-set hw-trans
crypto map np-cmap-outside 8 set security-association lifetime seconds 28800
crypto map np-cmap-outside 8 set security-association lifetime kilobytes 4608000
tunnel-group XX.XX.XX.20 type ipsec-l2l
tunnel-group XX.XX.XX.20 ipsec-attributes
 pre-shared-key *****
 isakmp keepalive threshold 120 retry 2
tunnel-group XX.XX.XX.132 type ipsec-l2l
tunnel-group XX.XX.XX.132 ipsec-attributes
Douglas Holmes
Not sure there is enough information to answer.  The fact that you are receiving ESP packets should mean that the other side of the connection is fully authenticated and therefore sending ESP.   You cleared the tunnel but on which side was it cleared "remote or local"?
Thank you for taking the time to assist me.
Tunnel was cleared from the local firewall. The remote firewall is not reporting any kind of authentication failure on their logs.
I'm able to ping the remote firewall, even some IP address that exists on certain SPI subnets on the remote side. So I'm guessing the authentication failure applies to some packet and not every signal packet that is transported through VPN.
Many Thanks
