07-28-2015 01:27 PM - edited 03-14-2019 03:03 PM
Hi All
Somebody knwo, how to get audio file system from UCCX, web o CLI??,
Best Regards
Solved! Go to Solution.
07-28-2015 07:09 PM
Do you mean to get the prompts uploaded in CCX ?
You can get them by hitting the folder icon.
This will give you a zip file, If you need the system prompts that are by default let me know.
Chakshu Piplani
Please rate helpful posts and mark correct answers.
07-28-2015 07:09 PM
Chakshu Piplani
07-31-2015 11:06 AM
Thanks a lot Chakshu, Also I need prompts by default
Regrads
07-31-2015 07:58 PM
Here you go:
https://supportforums.cisco.com/document/53326/contact-center-express-system-prompt-repository-details
