I have two static routes to the same destination network, they both have admin distance of 1 and cost of 0, what is the command to make one static route more preferred over another static route?
Am I right in saying the cost will need to be modified and not the administrative distance as both routes are from the same routing source? And administrative distance only comes into play when you have routes from different routing sources? Thanks
