PC can have connection, but why cannot MAC have Anyconnect VPN ?
eigrpy
Level 4
Level 4
Hi, We have MAC and PC users. Both users could reach inside network through ASA and Anyconnect VPN. however, MAC users cannot have connection(Please see screenshot in attachment). The output of command show run webvpn is below:
act(config-webvpn)# sh run webvpn
webvpn
 enable outside
 enable inside
 csd image disk0:/csd_3.5.841-k9.pkg
 anyconnect image disk0:/anyconnect-win-3.1.04066-k9.pkg 1
 anyconnect enable
 tunnel-group-list enable
 auto-signon allow ip 0.0.0.0 0.0.0.0 auth-type all
The configuration lacks "anyconnect image disk0:/anyconnect-macosx-i386-2.5.2014-k9.pkg" all the time. we do not think this is reason why MAC users cannot reach the inside network because we do not have this command for long time. Any one can give suggestion ? Thank you.
2 Accepted Solutions
Dinesh Moudgil
The best practice is that we have the anyconnect images on the ASA for all the OS.
Please add this command :
webvpn
anyconnect image disk0:/anyconnect-macosx-i386-2.5.2014-k9.pkg 2
Then share the output of show run webvpn and try connecting again.
Dinesh Moudgil
P.S. Please rate helpful posts.
Cisco Network Security Channel - https://www.youtube.com/c/CiscoNetSec/
> The question is the command for MAC was not there for long time. Why could it work when the command was not there ?
I'm not sure, but I remember that in older releases it was not needed to have *all* images installed in flash. Perhaps that changed sometime. Did you upgrade your ASA recently before the problems started?
5 Replies 5
You have to install images for all needed desktop-os. Here, add the Mac-image with sequence "2" and the Mac users should be able to connect.
Hi Thank you two! It work out. The following is its output.
webvpn
enable outside
enable inside
no anyconnect-essentials
anyconnect image disk0:/anyconnect-macosx-i386-3.1.05170-k9.pkg 2
anyconnect enable
I think you are right. I need to confirm if the ASA was upgraded recently. Thank you again.
Dinesh Moudgil
webvpn
Dinesh Moudgil
