07-29-2015 07:41 PM - edited 07-05-2021 03:39 AM
Can anyone throw some light on what the Back-up Primary Controller and Back-up Secondary Controller values entered within the Global Configuration menu under Wireless --> Access Points tab on the GUI screen of Cisco 5508 WLC.
Requirement:
We have about 150 APs on 5508 WLC, and all APs have the primary HA contorller value set as the home 5508 WLC itself. I need to configure a secondary controller value for all APs pointing to a secondary WLC. I want to know if I can achieve this by just adding the value within the Back-up Secondary WLC section under the global configuration tab, or do i have go into each AP and enter the secondary WLC value within each AP.
What does the global ocnfiguration does actually? Please forward any URLs or docs for reference.
Thanks in Advance.
Lovleen
07-29-2015 11:53 PM
IF there is no settings on each of the AP then the Global settings will take precedence.
Have you read of this: High Availability (SSO) Deployment Guide
HA SSO is far better than Backup-Controller settings because the APs will react faster (sub-second vs 22 seconds) and swing to the redundant controller. HA SSO also synchronize the settings so you don't need to apply the same settings (except allowed VLANs) on the other controller.
06-15-2016 01:01 PM
I am going to have two HA pairs. Can I set one pair as the primary controller, and the second pair as the secondary backup controller in the event of an HA pair failure?
06-15-2016 01:05 PM
Yes, it's possible.
06-15-2016 06:22 PM
Yes, it supports as primary and secondary as one pair, no 2 primary controllers or no 2 secondary controllers can be paired as HA, you can consider N+1 also.
