Replacing master switch on 3750E Stack
dilshansumesh1
Having a stack with WS-C3750E-24TD-S switches, need to replace the MASTER switch, any guidelines ?
Appreciate the support.
Sumesh
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You don't set a switch to master, per se, but you can set priorities such that highest priority wins stack election.
Yes, config survives master shutdown (there's a copy on every stack member).
Whether you need to set other switches' election priority depends on your intent and how they are currently configured.
Once you shut off the existing stack master another switch will become master.  You can, though, set which if will be via setting priorities.  (If all switches are alike, it shouldn't really matter much which switch is master, although there is a Cisco recommendation to have the master on a switch member with lower volume traffic.)
Role doesn't change port configs.
6 Replies 6
Leo Laohoo
Make sure the replacement switch has the same IOS version, feature set and license PAK as the existing stack.
Thanks for the advice, will check on that.
Sumesh
Joseph W. Doherty
Disclaimer
Posting
I'm assuming you want to keep the rest of the stack operational.
If not already using, you might want to consider using stack-mac persistent timer 0.
If you're running L3 on the stack, you might want to enable NSF.  Also if you're running L3, and stack master is active, is there another stack member with same feature license to take over?
If the master is still active, you can just power it down (also assuming you're using a dual ring).
You can then replace it, as you would any other powered off stack member.  Additional considerations apply if it's a different model.  It's ideal if replacement, also has same IOS version and license, but they don't always have to agree, especially license.  Again, though, if they do not, additional considerations apply.
Once the replacement is inserted into the ring, power it up, and it should join the stack.
If you want the replacement to become the active master, you'll need to at least bounce the active master and insure the replacement will win the stack master election.
Thanks for the support...
Yes it's running L3 and there are 6 identical switches running in the stack.
The MASTER switch is the one getting replaced and just wanted to know the following concerns.
Can we set the new switch to MASTER ?
Will the entire config stay after the replacement (since the MASTER is getting replaced) ?
Do I have to set the other switches on lower priority ? (Before the replacement)
And if another gets elected MASTER can we change the role without harming the existing port configs ?
Thanks in advance ...
Sumesh
Disclaimer
Posting
dilshansumesh1
Thanks Joseph W. Doherty,
You have cleared all my doubts.
Thanks again.
