07-31-2015 05:07 AM - edited 03-10-2019 06:25 AM
i am currently controling 2 devices with my Virtual Firesigt Center. i Wonder if it is not possible to create a dashboard for each devices.
i seems that the Dashboard collects all the data that comes to the firesigth, is it not possible to create some custom dashbord. with widgets that filter on reporting device or IP net.
08-02-2015 01:24 AM
Anyone ?
08-02-2015 06:34 AM
Dashboards are very customizable.
The process for doing so is described in the User Guide here.
08-29-2015 09:14 AM
Sorry for the delayed reply, i have looked into the User guide for dashboard. and i think that to get a custom widget for lets say top 10 Web application for SFR device 1 and a Witget for 10 Web application for SFR Device 2. then i need to use Custom Analysis widget, and then create a custom table, with the correct tables and fields, but i cant seem to figure out the correct way the create the custom table. i want the widget to display the result in total bytes.
