08-02-2015 02:20 AM
what is the difference between SRW2024P-K9 and SG300-28PP-K9 ?
Solved! Go to Solution.
08-04-2015 07:16 AM
Hi Peter,
Basically SRW2024P-K9 (order ID) is SG 300-28P (model name) so you are comparing this to SG300-28PP-K9. Double PP stands for PoE plus (802.3at PoE+ ) vs 802.3af PoE:
http://www.cisco.com/c/en/us/products/collateral/switches/small-business-smart-switches/data_sheet_c78-610061.html
I hope it helps,
Aleksandra
08-04-2015 07:33 AM
Peter,
Basically provided Watts:
..."The original IEEE 802.3af-2003[2] PoE standard provides up to 15.4 W of DC power (minimum 44 V DC and 350 mA[3][4]) to each device.[5] Only 12.95 W is assured to be available at the powered device as some power dissipates in the cable.[6]
The updated IEEE 802.3at-2009[7] PoE standard also known as PoE+ or PoE plus, provides up to 25.5 W of power.[8] The 2009 standard prohibits a powered device from using all four pairs for power.[9] Some vendors have announced products that claim to be compatible with the 802.3at standard and offer up to 51 W of power over a single cable by utilizing all four pairs in the Category 5 cable.[10]"...
https://en.wikipedia.org/wiki/Power_over_Ethernet
Aleksandra
08-04-2015 07:16 AM
Hi Peter,
I hope it helps,
Aleksandra
08-04-2015 07:22 AM
what is the difference between PoE plus and PoE ?
08-04-2015 07:33 AM
Peter,
Aleksandra
