Ring Voltage on Cisco VG202
junior.beatty
I have some modem devices I am trying to connect using VG202's that require a minimum ringing voltage of 48v.  How can I boost the ring voltage on the VG202, either through the config or adding a ring voltage booster.  Has anybody had to do this, I would love to hear your thoughts.  Thanks.
Manish Gogna
Please check the following posts with similar queries
https://supportforums.cisco.com/discussion/10637636/vg202-fax
https://supportforums.cisco.com/discussion/9973851/vg224-low-idle-voltage-rma-needed
Manish
- Do rate helpful posts -
