s2s connections to cisco.com
matthiasrie
I've noticed that I can't establish any connections to the cisco.com jabber servers since I've disabled unencrypted and poorly encrypted s2s connections. I think that's nearly impossible that cisco.com doesn't support encrypted s2s connections. Can you advise me cipher settings that should work with the cisco jabber servers?
Matthias Rieber
Chirag Vinchhi
Hi Matthias,
It's unclear what you are trying to achieve? Are you referring to s2s connection with cisco.com to federate with XMPP protocol?
Kindly describe your query in more detail. Thanks.
exactly, I'm referring to the s2s connection with cisco.com. The question is, is it really no possible to establish encrypted connections and if yes, are there any plans to change that.
Kind Regads,
Matthias
