08-04-2015 09:36 AM - edited 03-17-2019 03:52 AM
hi mates,
got new phones, 8851 and 8841 series phones, how do you reset them by factory default and a standard refresh reset?
is it pound pound star pound?
cheers,
matt
08-04-2015 09:43 AM
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8811_8841_8851_8861/10_5/english/adminguide/P881_BK_C0632068_00_cisco-ip-phone-8811-8841/P881_BK_C0632068_00_cisco-ip-phone-8811-8841_chapter_01111.html
08-04-2015 10:11 AM
thanks mates,
is there another way to reset the phone without using the factory reset?
cheers,
matt
08-04-2015 10:20 AM
You can reset a phone with any of these operations after the phone has started up. Choose the operation that is appropriate for your situation.
Operation | Action | Explanation |
Restart phone | Press Services, Applications, or Directoriesand then press **#**. | Resets any user and network setup changes that you have made, but that the phone has not written to its Flash memory, to previously saved settings, then restarts the phone. |
Reset settings | To reset settings, press Applications and choose Administrator Settings > Reset Settings > Network. | Resets user and network setup settings to their default values, and restarts the phone. |
To reset the CTL file, press Applications and choose Administrator Settings > Reset Settings > Security. | Resets the CTL file. |
08-04-2015 04:00 PM
is there a way to unlock a 8851 or 8841 model phone?
cheers,matt
08-04-2015 04:49 PM
Hello!
The Factory reset procedure is incorrect on 88xx admin guide (Below is Cisco BUG ID)
CSCut29814
Symptom:
The keypad button factory reset procedure in the 8841/51/61 Administration Guide is not accurate.
Conditions:
When attempting the keypad button factory reset procedure documented in the 8841/51/61 administration guide, the phone never reaches the state where "all other lights stay green."
Workaround:
The correct procedure is:
1. Press "#" when you power on the phone
2. You will see the headset,speaker and mute will light on and then light off.
3. When you see only headset and speaker turn on again, please press 123456789*0# in sequence.
4. After you pressed the the first digit "1", you will see speaker turn off.
5. After all the number are input completely in sequence, you will see Mute button turns on to indicate phone begin to do the factory reset.
Hope that helps!!
Charlie
