08-05-2015 10:41 AM - edited 03-10-2019 10:57 PM
Hello group,
I am having troubles setting up a configuration where the customer wants to enable Anyconnect access to the network using their existing ASA, ACS and RSA. The customer wants to use the user database from his AD.
The customer wants the ASA to use the ACS 5.X using Radius and wants his ACS to use the RSA server. The VPN users should use their tokens to connect.
I have found several configuration examples but I just can't figure out how to make it work.
I have the ASA configured to authenticate the VPN users using the radius server.
Here is the portion of configuration on the ASA:
AAA CONFIGURATION – ACS SERVER
aaa-server RADIUS protocol radius
aaa-server RADIUS (INSIDE) host 192.168.1.1
key Thi$i$aT3sT
aaa-server RADIUS (INSIDE) host 192.168.1.2
key Thi$i$aT3sT
SSL VPN CONFIGURATION
group-policy SSL-VPN internal
group-policy SSL-VPN attributes
dns-server value 10.80.1.10 172.16.48.40
vpn-tunnel-protocol ssl-client ssl-clientless
split-tunnel-policy tunnelspecified
split-tunnel-network-list value VPN-LIST
default-domain value example.com
webvpn
customization value DfltCustomization
tunnel-group SSL-VPN type remote-access
tunnel-group SSL-VPN general-attributes
address-pool vpnpool
authentication-server-group RADIUS LOCAL
default-group-policy SSL-VPN
tunnel-group SSL-VPN webvpn-attributes
group-alias SSL-VPN enable
For the ACS and RSA I followed the following link:
I don't seem to find the right policy on the ACS to make this work. The link doesn't show how to configure the authentication/authorization policies.
I found this other link but it shows how to setup the configuration for device administration not for network access.
https://popravak.wordpress.com/2013/02/16/using-rsa-securid-external-database-with-cisco-acs-5-x/
Any advise?
12-23-2015 07:22 PM
Paul,
having same issue here. were you able to figure this out?
cant seem to find good doc on it.
thanks
12-28-2015 03:50 PM
Configure the ACS server to use the rsa identity source for the vpn authentications. You may need to change your authentication policies to send all vpn requests to the rsa server and set any other radius request to the default identity store before you make this change. From there the integration between acs and rsa will complete it self.
01-05-2016 05:22 AM
I also intend to configure this short enough. Can someone add more details on this? Like full configuration of ASA and ACS?
02-02-2016 02:54 AM
Hi team,
I'm also interested in this deployment. We have the same elements and we are looking for the same goal: the 2-factor authentication for VPN via AnyConnect.
The flow should be:
AnyConnect Client -> Cisco ASA -> Cisco ACS -> (RSA) and (AD)
or
AnyConnect Client -> Cisco ASA -> (RSA) and (Cisco ACS -> AD)
Best Regards
02-02-2016 08:09 AM
Hi Paul,
I'm having this issue as well. Could you please let me know how you resolve it? Which protocols have you used? It is possible to configure ACS in order to get two-factor authentication?
Thanks in advance!
