08-06-2015 05:58 AM - edited 03-21-2019 10:27 AM
Good afternoon, community. I bought a set of SPA302DKIT-G7 (Dect phone and adapter to connect to it for SIP). Configured SIP accounts. Outgoing calls work, but inbound calls are not. At adapters web access i see "Line 1 Status,Call 1 State:Ringing " when I an calling, but the call is not being transferred to the handset. Bindings to the tube are both incoming and outgoing number. Any idea why this might be?
Solved! Go to Solution.
08-06-2015 03:52 PM
I have no SPA232D here now, but the Line 1 is analog line, not the DECT handset, isn't it ?
So it look like improper setup - incoming call is routed to POTS line. If you wish to be routed elsewhere (e.g. to a particular DECT handset) you need to configure it accordingly.
Unfortunately, you didn't described the failing scenario so much so it's hard to provide more precise advice.
08-06-2015 03:52 PM
