NMS Edge switch not responding
Brendan Marmont
Our NMS is unable to ping some edge switches, however able to ping others.
There are no static routes on the sw, when I execute 'sh ip route' three addresses come back plus def gw..
Host               Gateway           Last Use    Total Uses  Interface
The Default Gateway is correct, however there are three hosts that point to a redundant circuit, one being the NMS Host, how do I clear this?
Thanks!
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C3560-48PS      12.2(55)SE10          C3560-IPSERVICESK9-M
Mark Malone
You need to look at where its learning the route from and why its learning a route to a redundant link and does not have the primary route anymore as i presume this was working before
compare it to a route that's working correctly on the NMS switch and see what the difference is
