Configuration missing after upgraded IOS router 7600 from 12.2(33)SRD3 to SRE10.
Such as:
(config)#mls ip multicast flow-stat-timer 9
Warning: This command is no longer supported.
snmp-server enable traps ethernet cfm alarm
ip nat inside source list 114 pool pool_vrf_DR vrf DR
ip nat inside source static 172.16.76.66 10.10.58.1 vrf MR
How should I do?
Thank you very much.
I found it is a bug CSCtn26796.
