08-13-2015 09:09 PM - edited 03-11-2019 11:25 PM
Dear all,
My English is'n good . I have trouble with static nat on asa run version 9.1.
This is my configuration file
interface GigabitEthernet1/1
nameif outside
des # Connect to router of ISP #
security-level 0
ip address 222.255.23.166 255.255.255.252
!interface GigabitEthernet0/2
nameif dmz
security-level 50
ip address 199.1.10.33 255.255.255.224
route outside 0.0.0.0 0.0.0.0 222.255.23.165 1
object network NASU_DMZ
sub 199.1.10.32 255.255.255.224
objecdt network NASU_ISA
host 199.1.10.62
objecdt network NASU_ISA_PUB
host 222.255.20.186
nat (dmz,outside) after-auto source dynamic NASU_DMZ interface
nat (dmz,outside) source static NASU_ISA NASU_ISA_PUB (static nat)
Case1 : if I use alc " access-list Outside_policy_in extendend permit ip any any " ,
access-group Outside_policy_in in interface outside
Result: Static nat on ASA will be worked correct
Case 2 : If I use acl " access-list Outside_policy_in extendend permit tcp any host 222.255.20.186 eq 443
access-list Outside_policy_in extendend permit tcp any host 222.255.20.186 eq 80
Result: Static nat on ASA will be worked incorrect. I can't use all service include 443 and 80 .
Can you help me solve this problem ?
Thank you very much!
Solved! Go to Solution.
08-14-2015 01:22 AM
In the ACL you have to use the real server IP-address:
access-list Outside_policy_in extendend permit tcp any object NASU_ISA eq 443 access-list Outside_policy_in extendend permit tcp any object NASU_ISA eq 80
08-14-2015 01:22 AM
08-14-2015 11:18 AM
Thank for your support !
So, can you explain for me? All document show me that have to use IP map with static nat on asa.
08-14-2015 12:11 PM
The translated address was used in the ACL in ASA versions up to 8.2. With the new NAT-model it changed that the real IP has to be used.
